Questions
Old Oct 23, 2008 | 02:25 AM
2006sssc's Avatar
Questions
Hey guys,
Just wondering about the following looking for some help. i am looking to get stage 2or3
most likely 3 lol. but should i acutually get a stage kit or should i just get 60's and a 2.8...also i am going to do a wet 50shot..and also what should i do for a tune can someone just tune the stock ECU im not to sure thats why im asking..would also be puttin a full 3' custom exhaust..and as for a header not sure if i should or not because some ppl say it doesnt help at all..so let me know what you guys think like if i would/will run into any problems..also wondering what you guys think i will hit for numbers
Thanks in advance
Jordan
Old Oct 23, 2008 | 02:28 AM
Acey's Avatar
No header "doesn't help at all" as far as I know, though some are significantly better than others.
Sounds like you have some reading to do. There are about a dozen stickies in this section.
Old Oct 23, 2008 | 02:35 AM
EXsoccer1921's Avatar
i gave a girl a wet shot 50 times once and she......oh sorry wrong thread.
but no seriously. go with a 2.7, 60's, tune, cx racing heat exchanger, dual pass w/ option b, and the 50 shot. you'll be golden
Old Oct 23, 2008 | 10:06 AM
Littlegoose's Avatar
As mentioned above, stock exhaust manifold is extremely restrictive. If you plan on going with smaller pulley sizes dont go with stage 3 because from what I've read (god knows don't go off of that though) the PCM is locked and cannot be tuned.
If you're planning on doing the stuff you're talking about don't mess with GM stage tunes. You'll spend more money and get less performance, only to soon have the desire for more in which case you'll surpass either of the stage kits capabilities. I'd concentrate on cooling and traction mods first so you can put the power to the ground and do it safely & without heatsoaking out the ass. When you start going for power mods make sure you have the stuff needed to monitor all the things necessary so you know how safe you're running or what kind of problems you're having.
Old Oct 23, 2008 | 10:14 AM
ShortStack's Avatar
and oh btw... header = the ****... Best to get a downpipe along with it..
The person who said it wouldnt help just didnt want you to be faster than them.
Old Oct 23, 2008 | 04:33 PM
2006sssc's Avatar
Thanks alot guy..another thing i was just wondering with my setup is there any other little odds and ends that i would need to pick up for example spark plugs or anything like that..basically anything else i will need to run my setup save and smooth and also to bring my best numbers out
Thanks in advance
Jordan
Old Oct 23, 2008 | 04:37 PM
ShortStack's Avatar
always change your spark plugs... about every time you change your oil.. is a good mark...
Old Oct 23, 2008 | 04:47 PM
tobz's Avatar
Changing spark plugs every 5k - 10k miles?
What a waste of money.
Old Oct 23, 2008 | 07:34 PM
brandondrecksage's Avatar
lol...
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
