Questions about my cobalt's performance
Old Mar 14, 2012 | 12:02 PM
CarTunezSS's Avatar
Originally Posted by sujomatt
Is it an aftermarket DP?
if it is, i didnt get it put on.
Old Mar 14, 2012 | 12:06 PM
07LSJ's Avatar
goign twincharged huh? good luck.
Old Mar 14, 2012 | 12:14 PM
CarTunezSS's Avatar
why? from the looks, it seems pretty easy as far as the install goes.
Old Mar 14, 2012 | 12:16 PM
07LSJ's Avatar
when you start, make a build thread, ill sub.
Old Mar 14, 2012 | 01:06 PM
insylem's Avatar
Originally Posted by Jdam8139
You got it backwards. An open exhaust system will cause boost to drop. Since there's less restriction on the hot side, the blower doesn't build as much pressure. Freeing up the intake side (pre-blower), however, will cause boost to go up. Think of it as trying to blow through a straw (a lot of restriction) then trying to blow through a piece of PVC (virtually no restriction). Pressure inside the PVC is a lot lower than inside the straw. Same principle applies here.
OP: If you're boosting to 20psi, you are either running a 2.7 or smaller ( I saw 17psi on my 2.7 before the belt blew up), or you have a massively clogged cat causing serious restriction and therefore uber boost
Yes
M62 = Air Pump
Pump = Create flow
Restriction = Create Pressure
Naturally the harder and engine works the more resistance there is, thus higher intake manifold pressures. If you never modify the engine, and always run it at the same RPM you could use your boost gauge as a measurment of howh ard the engine is working.
Free up the exhaust, the engine doesnt have to work as hard to expell the exhaust, your boost levels go down...
When I got my ZZP Header/Downpipe installed I boosted 17PSI (2.85" Pulley) With stock exhaust, and 15-16 PSI with the ZZP exhaust. Also went from 232 whp to 239 whp just adding the ZZP Long tube header/downpipe combo.
Only ever went to the track once, and I hit 18 PSI on the track, that was after the ZZP Exhaust. Seeing as everything ealse was the same, even RPM (Ran to 7K) I can comfortable say that my car put down more HP on the track then it did to the dyno. Not sure why that happens, Guess thats why people say real numbers come from the track insteadof the dyno.
Old Mar 14, 2012 | 04:55 PM
CarTunezSS's Avatar
the number on the pulley says 77.9mm
Old Mar 14, 2012 | 04:56 PM
CarTunezSS's Avatar
this is the exhaust
Old Mar 14, 2012 | 05:06 PM
CarTunezSS's Avatar
a clogged Cat will cause 20 PSI on a m62.
the cat and resonator are brand new from the dealership a few months ago.
Old Mar 14, 2012 | 05:08 PM
drumrush's Avatar
that is a gm stage 2 pulley. shouldnt be anywhere near 20psi. i have a smaller pulley on my 2.2 and im only at 12
Old Mar 14, 2012 | 05:09 PM
07LSJ's Avatar
i think thats 3". not stock. injectors?
Old Mar 14, 2012 | 05:15 PM
  #36
CarTunezSS's Avatar
i cant c the injectors
Old Mar 14, 2012 | 06:23 PM
  #37
mrbelvedere's Avatar
you also have a bigger engine more cubes on the same pully equals less boost op just because the cat is new dosent mean its good
Old Mar 14, 2012 | 09:11 PM
  #38
drumrush's Avatar
That's true, but it won't make a difference of 8 psi
Old Mar 14, 2012 | 10:29 PM
  #39
Whitnith's Avatar
There is a strong Cobalt community in Chicago, with a couple guys who know these things inside and out.
Join facebook.com/ChicagoEcotec
Post up, they can help you out. Will probably even offer to come check the car out in person and really see what is up with it.
Old Mar 14, 2012 | 10:30 PM
  #40
Jdam8139's Avatar
Kinda far-fetched but what if there's a damper installed it could cause him to be boosting higher on a s2 pulley. I'm not real familiar on how they work or I'd offer more info, but I know ZZP advertises that the "GM ECOTEC Super Damper" will effectively drop a pulley size without dropping a pulley size. That would be about right.....
3.0"-->2.8" = 15#-->20#
Old Mar 14, 2012 | 10:49 PM
  #41
well considering a 2.4 and a 2.6 pully on a m62 only makes 12lbs of boost but this guys problem is something is pluged either the cat or the muffler
you are way off dropping 1 size isent gonna give 5lbs or so increase and i would bet that it still has the stock dampner
nice wheels and a good idea
Last edited by mrbelvedere; Mar 14, 2012 at 10:49 PM. Reason: Automerged Doublepost
Old Mar 14, 2012 | 11:06 PM
  #42
jonnymerk's Avatar
Originally Posted by CarTunezSS
there are zero cooling mods from what i see too... and it's kinda freaking me out.
anyone here twincharging? i have parts from a turbo build that i wanna throw on there.
i read a sticky thread saying yall throw in extra injectors for tuning and what not.
Get the rest of the parts you need to be just turbo or sell them.
Old Mar 14, 2012 | 11:27 PM
  #43
Bluelightning's Avatar
Got Bewst?
Originally Posted by insylem
Yes
M62 = Air Pump
Pump = Create flow
Because a dyno is a piece of machinery. It's just a tuning tool. You can go to 3 different dyno's and get 3 different numbers. The track doesn't lie.
Old Mar 14, 2012 | 11:33 PM
  #44
advise's Avatar
could be a cobalt addicition pulley with the 77.9 stamp but its really a 2.8
Old Mar 15, 2012 | 07:14 AM
  #45
Tjolley's Avatar
I'm running a 2.5 pulley on a ported and polished m62.. with a z z performance long tube header catless downpipe and 3 inch exhaust. and I hit 19.5 psi
Old Mar 15, 2012 | 07:41 AM
  #46
Tjolley's Avatar
https://www.youtube.com/watch?v=BGle...e_gdata_player
not the greatest video quality but it'll give you an idea
Sean Cummings
Jan 8, 2020 10:17 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
Rayray2781@gmail.com
Sep 9, 2015 10:40 AM
CobaltSS 16
Sep 6, 2015 02:04 PM
