Quick exhaust question
Just wanna make sure that the ZZP header/downpipe combo will work with my corsa touring exhaust. Corsa is 2.5inch i believe so if i go with the 2.5 downpipe it will all bolt up rite?
What do you guys think, 1 3/4 header or 1 1/2 header? Its only $20 more for the 1 3/4. I made about 270whp with stock exhaust, which should i get?
does the 1/4 inch really make that much of a difference. i know my GMPP manifold and stock dp are holding the car back, so im just trying to liven things up. its only $20 more for the 1 3/4 over the 1 1/2 so i might as well get the bigger header. Any down sides to the larger header?
i have the zzp combo on, hooked up to the GMPP sport exhuast. I have the 2.5DP and my header has the 1.5 primairies. sounds great and fit perfectly.
edit: forced_induction, what are you mods? you say you made 270WHP, im curious to what your mods are.
ZZP 2.7 pulley, NKG 1 step colder plugs, 60 pound fuel injectors, Injen CAI, Corsa touring exhaust, GMPP exhaust manifold, Tuned By Matt at Tune Time, Dynoed 270whp 230tq without exhaust
lol, dude it will fit up perfectly. i had the same problem... did you even search this?? i had a few problems but nothing big. i freaked out cause i thought it wasnt long enough but i just had to pull on the exhaust. haahha
HERE YOU GO. I SEARCHED FOR YOU
https://www.cobaltss.net/forums/problems-service-maintenance-69/zzp-header-dp-corsa-exhaust-problem-89202/
i was gonna get the 2.5in DP since my corsa cat back is 2.5in. Im still pretty new to all of this, its my first car i have modded so bare with me lol. Wont it bottle neck?
thanks bro, didn't realize it would make that much of a difference
No it won't bottleneck. Just order the 3" downpipe with a 2.5" connection for your catback Everyone with an LSJ runs a 3" dp on this forum. Going with a 2.5" is a waste and will just rob you of power.
Just imagine how much more power you'd make with the bigger header. The LSJ should NEVER be ordered with less then 1 3/4th
Last edited by Onyxd04Redline; 03-02-2008 at 03:52 PM. Reason: Automerged Doublepost
