zzp header/dp to corsa exhaust problem
Old Dec 18, 2007 | 04:12 PM
ColeJJones's Avatar
Bannned
ok i just jacked my car up right now and im getting ready to install my midlength header/dp from zzp. but it looks like if i take off the stock header and dp and i put on the zzp combo it wont reach my exhaust! anyone have the zzp midlength header/dp installed ??? and what exhaust did you hook it up to? need help please
Old Dec 18, 2007 | 04:14 PM
stryder's Avatar
don't worry man it will fit up fine.
Old Dec 18, 2007 | 04:15 PM
Co|3aLt $$'s Avatar
did you get it off of the group buy?
Old Dec 18, 2007 | 04:16 PM
ColeJJones's Avatar
Bannned
nope
Old Dec 18, 2007 | 04:17 PM
stryder's Avatar
it works with the gmpp, megan, borla, corsa, magnaflow etc. take a pic if you can of where your problom is. and you might want to get different bolts for the header to downpipe, the ones zzp sent you suck and WILL break on you.
Co|3aLt $$'s Avatar
ooo it says it should fit up to stock... does yours meet the same specs? (the exhaust that is)
Old Dec 18, 2007 | 04:18 PM
stryder's Avatar
I have installed atleast 5 of them on different exhaust setups and it fit perfectly each time.
Old Dec 18, 2007 | 04:19 PM
D4u2s0t's Avatar
it's probably because the flex pipe is not stretched. once you get it on, the flex pipe should have a little leeway, and reach. may have to pull it a little but it will fit.
Old Dec 18, 2007 | 04:20 PM
stryder's Avatar
yeah thats what i was thinking too.
Old Dec 18, 2007 | 04:22 PM
06_SS_S/C's Avatar
It will fit.
Old Dec 18, 2007 | 04:23 PM
Co|3aLt $$'s Avatar
I heard they put diff. bolts in with the kit? the ones I got aren't bad at all.. (at least they don't seem to be)
Old Dec 18, 2007 | 04:27 PM
SuperchargedSS's Avatar
Yeah the bolts have been swapped, its a good kit. I have the same setup. I have seen the old bolts too, I wouldnt have used them to hang a bird feeder.
EDIT: The sound of that combo is going to make you drool.
Old Dec 18, 2007 | 05:08 PM
ColeJJones's Avatar
Bannned
lol, i hope so. its already loud. i just pulled off the dp. i took a pic of the stock and zzp next to each other. let me upload it real fast...
Last edited by ColeJJones; Dec 18, 2007 at 05:08 PM. Reason: Automerged Doublepost
Old Dec 18, 2007 | 05:10 PM
D4u2s0t's Avatar
i used to have that same jack, then i switched from the 2 ton to the 3 ton. what a difference! has a much longer pump handle too.
Old Dec 18, 2007 | 05:11 PM
ColeJJones's Avatar
Bannned
lol, thanks for noticing my dp! haha
yes, that is smirnoff ice in the bottom corner too if anyone says anything
Last edited by ColeJJones; Dec 18, 2007 at 05:11 PM. Reason: Automerged Doublepost
Old Dec 18, 2007 | 05:12 PM
D4u2s0t's Avatar
sorry! i have the same header/dp but it's a christmas gift so i'll get it next week can't wait to get it on. post up some sound clips, or at least what it sounds like when it's on!
Old Dec 18, 2007 | 05:13 PM
ColeJJones's Avatar
Bannned
look how much smaller it is! how the hell is that supposed to fit to my exhaust???
Old Dec 18, 2007 | 05:17 PM
omgshesaboy's Avatar
does the header come down further than the stock one?
Old Dec 18, 2007 | 05:18 PM
ColeJJones's Avatar
Bannned
stryder... what the hell man. it will fit?
yea.. but not by much. that is the only thing that im thinking...
Last edited by ColeJJones; Dec 18, 2007 at 05:18 PM. Reason: Automerged Doublepost
BLAZIN07SS's Avatar
I'm too JDM for you
your header is longer(mid-length) than the stock lsj one, therefore your downpipe will not need to be as long
Old Dec 18, 2007 | 05:19 PM
sick06cobalt's Avatar
do you have the header off too? put that up with the header from the other one and look at it.. its the same...
Old Dec 18, 2007 | 05:20 PM
D4u2s0t's Avatar
it's a mid length, not a shorty header. the header is longer than stock. that's why the dp is shorter.
stop worrying, it will fit
Old Dec 18, 2007 | 05:23 PM
ecotecon18s's Avatar
ok, now post comparison pics of the headers side by side...
Old Dec 18, 2007 | 05:32 PM
ColeJJones's Avatar
Bannned
ok im just a lil stressed. im taking the header off now.
im holding the dp to the corso...
and you can see how far the flex pipe is from the stock header..
Last edited by ColeJJones; Dec 18, 2007 at 05:32 PM. Reason: Automerged Doublepost
Old Dec 18, 2007 | 05:34 PM
elecblue06's Avatar
you can only use the zzp midlength dp with their midlength header
and the combo will bolt up to any exhaust that bolts to the stock dp
