zzp header/dp to corsa exhaust problem
ok im using it for the rear now. you have to crush the heat shield in for it fit in cause it sticks out so far. but the threads are stripped or something cause it wont screw in the dp. i have tried for the last 15 minutes just to screw that damn thing in
i used it for the front first cause the the sensor cord sits on a bracket which i took off. but if you hook it up to the zzp header you cant use the bracket anymore cause you have to stretch if further, thats why i used the extention.
Last edited by ColeJJones; Dec 19, 2007 at 04:04 PM. Reason: Automerged Doublepost
lol, yea, the first part of the thread is thick and then it goes the normal thin to fit the bung.
do i have to put my stock heat shield back on?
it starts off all messed up
should i try and file it or what?
Last edited by ColeJJones; Dec 19, 2007 at 04:39 PM. Reason: Automerged Doublepost
what are you talking about? my rear 02 is stripped, i took it off the stock dp. how is it zzp's problem that i have a stripped 02 sensor? they just give an extention not a sensor
