zzp header/dp to corsa exhaust problem
Old Dec 19, 2007 | 01:14 PM
  #76
freakta's Avatar
dammit i got all excited i thought you were gonna have both vids i didnt scroll down far enough. o well glad to see you are having fun out there
Old Dec 19, 2007 | 02:35 PM
  #77
elecblue06's Avatar
Originally Posted by ColeJJones
yea, i will be careful. but still. this really does suck!
it bolts up perfectly with with the stock dp/ header... wtf
umm thats why.. it's the short DP with the stock header it WILL NOT FIT>...
Old Dec 19, 2007 | 02:46 PM
  #78
SuperchargedSS's Avatar
Originally Posted by Co|3aLt $$
hahahahahahahaha raisin bag
..........................BWAAAHAHAHAHAHAHAHa
A classic for sure...
Cant wait for the after video.... I noticed the touring tip is different than my Sport tip. **** my car is loud when its cold out. Corsa rocks.
Old Dec 19, 2007 | 03:17 PM
  #79
ColeJJones's Avatar
Bannned
houston we have a problem... my rear o2 sensor wont reach!
Old Dec 19, 2007 | 03:25 PM
  #80
Co|3aLt $$'s Avatar
should come with an extension in a little baggie with the original screws...??
Old Dec 19, 2007 | 03:29 PM
  #81
ColeJJones's Avatar
Bannned
it did... i used if for the front 02 sensor.
Old Dec 19, 2007 | 03:35 PM
  #82
elecblue06's Avatar
did you buy this used? and is it just the DP or is it the header DP combo / is it the DP from the combo.. these questions need to be answered
Old Dec 19, 2007 | 03:41 PM
  #83
06_SS_S/C's Avatar
You shouldn;'t need an extension for the front, only for the rear O2 sensor.
Old Dec 19, 2007 | 03:47 PM
  #84
D4u2s0t's Avatar
exactly
  #85
Co|3aLt $$'s Avatar
*whew* that's what I thought too glad that was confirmed.
Old Dec 19, 2007 | 04:04 PM
  #86
ColeJJones's Avatar
Bannned
ok im using it for the rear now. you have to crush the heat shield in for it fit in cause it sticks out so far. but the threads are stripped or something cause it wont screw in the dp. i have tried for the last 15 minutes just to screw that damn thing in
i used it for the front first cause the the sensor cord sits on a bracket which i took off. but if you hook it up to the zzp header you cant use the bracket anymore cause you have to stretch if further, thats why i used the extention.
Last edited by ColeJJones; Dec 19, 2007 at 04:04 PM. Reason: Automerged Doublepost
  #87
D4u2s0t's Avatar
are you sure you're spinning it the right way sorry, had to ask. look at the threads and see if they're stripped or not.
Old Dec 19, 2007 | 04:39 PM
  #88
ColeJJones's Avatar
Bannned
lol, yea, the first part of the thread is thick and then it goes the normal thin to fit the bung.
do i have to put my stock heat shield back on?
it starts off all messed up
should i try and file it or what?
Last edited by ColeJJones; Dec 19, 2007 at 04:39 PM. Reason: Automerged Doublepost
Old Dec 19, 2007 | 05:36 PM
  #89
rukkee's Avatar
WOW , this is kinda like EXHAUST QUEST , I would get a new 02 rather than taking the chance of screwing up the threads in the bung but thats just me .
Old Dec 19, 2007 | 05:38 PM
  #90
ColeJJones's Avatar
Bannned
i just called the gm dealer. its 163 to order a new one!
Old Dec 19, 2007 | 05:48 PM
  #91
D4u2s0t's Avatar
if you think you have a bad part, why are you calling the dealer instead of the company that you bought it from? the one you get from the dealer won't be long enough, it will be just like the stock one.
Old Dec 19, 2007 | 05:54 PM
  #92
ColeJJones's Avatar
Bannned
what are you talking about? my rear 02 is stripped, i took it off the stock dp. how is it zzp's problem that i have a stripped 02 sensor? they just give an extention not a sensor
Old Dec 19, 2007 | 05:56 PM
  #93
ted5986's Avatar
i say just file that biotch make sure it screws in smoothly by hand. if not file some more
Old Dec 19, 2007 | 05:58 PM
  #94
ColeJJones's Avatar
Bannned
i just need a damn file now
Old Dec 19, 2007 | 06:13 PM
  #95
D4u2s0t's Avatar
o i thought they give a whole new sensor... my bad! but still, dealer is rediculous
Old Dec 19, 2007 | 06:16 PM
  #96
ColeJJones's Avatar
Bannned
hell yea, im so screwed. i need to go out tonight. and i cant do **** because of this. i cant go anywhere! so gay
Old Dec 19, 2007 | 06:17 PM
  #97
D4u2s0t's Avatar
didn't notice when you first took it out i guess? that sucks, i hope it works out bro.
Old Dec 19, 2007 | 06:21 PM
  #98
ColeJJones's Avatar
Bannned
i asked the dealer if i leave it off what would happen? he said it would run lean or rich. he wasnt sure. what will happen if i leave the rear 02 sensor off??
Old Dec 19, 2007 | 06:45 PM
  #99
saunders1986's Avatar
rear o2 sensor just tells u if ur cat is on its way out, but if its not in there u'll get a exhaust leak
Old Dec 19, 2007 | 06:55 PM
  #100
ecotecon18s's Avatar
CEL for sure...car might run like ****...
