Quick HP Tuners question
Old Jul 12, 2008 | 05:10 PM
mjesenovec's Avatar
so a good friend of mine offered to disable my rear O2 sensor with hptuners. I got a zzp header/dp and i'm tired of looking at the CEL. he said it was like 50 bucks for the license or whatever, no big deal. what he wants to know, is what values need to be changed to disable the rear o2? is he just going to set the parameters to 0? do they need to be set to certain settings? he's most familir with LSx series motors, and said he wanted to make sure he was doing the right thing to disable my o2.
also, since my car will be unlocked and we will be free to change anything we want...are there any other adjustments or minor tuning i could do that would make any sort of difference? i only have an AEM airbox mod, zzp header/dp, and gmpp catback....so basically intake and full exhaust. i wont be getting my rebel autowerks stage kit until later this year...but i was just wondering if there's any minor things you all recommend be changed since he'll do it for free.
Old Jul 12, 2008 | 05:15 PM
an0malous's Avatar
its 100 for the licence
there is a sticky showing which codes need to be turned off.
Old Jul 12, 2008 | 07:58 PM
mjesenovec's Avatar
cool, thanks, i'll check out the codes. he looked online, and told me he could get the license for 50...but i'll see what's up when i get it done.
uhh...i can't find that sticky. i just looked in about half the forums, and there was no sticky with HP tuners configurations.
bump. i can't find the sticky...and i would still like an answer about other possible settings i could change for some benefit.
Last edited by mjesenovec; Jul 12, 2008 at 08:05 PM. Reason: Automerged Doublepost
Old Jul 12, 2008 | 10:27 PM
Doc's Avatar
Doc
here....
Eliminating the rear O2 sensor
Engine Diagnostics>DTC's
for the following codes, uncheck the SES option and set the ERROR MODE to 3-No Error Reported
P0036
P0054
P0136-P0141
P0420
I believe thats it, all the ones you want to turn off are labeled HO2S..........sensor 2
Old Jul 13, 2008 | 12:38 PM
mjesenovec's Avatar
Originally Posted by Doc
here....
thanks doc! you're the man. do you have any insight on the other part of my question? do you know of any other parameters that i should toggle while we're in the hp tuners?
Old Jul 13, 2008 | 12:41 PM
Doc's Avatar
Doc
here.....this is posted somewhere on this forum, if not, its in the forum for my sig in the tuning section
DISCLAIMER - I AM NOT RESPONSIBLE FOR THE CHANGES YOU MAKE TO YOUR CAR
Ok, let me go one thing at a time..
The rev-limiter
Engine>Fuel Control>Fuel Cut-off>RPM Limits
change the Fuel Cutoff RPM P/N vs. ECT to your desired rpm
change the Fuel Cutoff RPM vs Gear to your desired rpm
change the Fuel Cutoff RPM 1st Gear vs. Time to your desired rpm
P0036
P0054
P0136-P0141
P0420
For those without a cat, also turn off COT (set the values to 0)
Engine>Fuel Control>COT Lean Cruise>COT Adder Max
Engine>Fuel Control>COT Lean Cruise>COT Adder Min
Now, I use another couple tricks.
Limited boost in first
Engine>Torque Management>Supercharger>Max Boost 1st Gear
Labels 4000/4250/ 4500/4750/5000/5250/5500/5750/6000/6250/6500-8000 (at 100%)
Max Boost 40/45/55/60/65/75/80/85/90/95/100
Torque Management
Engine>Torque Management>General>Spark Retard vs Torque Reduction
set all values to ZERO
Transmission>Torque Management>Abuse Mode>Trans Abuse Mode Torque Reduction vs. RPM
Transmission>Torque Management>Torque Reduction>Torque Reduction vs Torque vs Shift-Normal
Transmission>Torque Management>Torque Reduction>Torque Reduction vs Torque vs Shift-Performance
these are simply ways to accomplish a goal.
Old Jul 13, 2008 | 01:04 PM
mjesenovec's Avatar
WOW...thanks again. what exactly is the torque management stuff? why is it there? and....what would be the benefit of changing it?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
