Quick question
Old Apr 6, 2010 | 12:56 PM
Aaron-0703's Avatar
Quick question
So can I take my bros old gm stage 2 PCM outta his 06 ss n put it in my 06 ss if I get a new authorization code from gm?
Old Apr 6, 2010 | 12:58 PM
MT0911's Avatar
It won't work unless you bought the kit brand new. GM doesn't hand out the authorization codes. The code is part of the purchase when you buy GM Stage 2. You're better off getting a custom tune.
Old Apr 6, 2010 | 01:00 PM
06G85's Avatar
If you installed all the stage 2 parts on your car, all you would need to do is the following:
1) Have the dealer flash your VIN into the PCM you're installing
2) Have the dealer do a case relearn (or crank relearn I can't remember)
3) Have the dealer do a security relearn
I believe that's all you need to do...
What I did was I bought used 42lb injectors, then I bought the stage 1 to 2 upgrade kit. ($350 from CED)
Comes with an authorization code.
Old Apr 6, 2010 | 01:07 PM
Aaron-0703's Avatar
Lol acually n authorization code was handed to me I dnt want custom bc warrentie.. So can I use PCM with new code?
Old Apr 6, 2010 | 01:08 PM
MT0911's Avatar
So you ended up getting the stage 1 to 2 upgrade kit? not a bad idea. How's it driving for you so far?
how did you get this "new" authorization code?
Old Apr 6, 2010 | 01:12 PM
Aaron-0703's Avatar
Lol it was a gift got the stage 1 to 2... So would I b able to use PCM?
Old Apr 6, 2010 | 01:16 PM
MT0911's Avatar
Well actually if you have the authorization code and the parts already you don't even need his pcm. You can just go get your's flashed.
Old Apr 6, 2010 | 02:53 PM
Aaron-0703's Avatar
Sweet
O but I have a intense PCM on there that I wanna take off.. Can I use the used gm PCM
Old Apr 6, 2010 | 03:38 PM
YzRider452's Avatar
just get an hp tune. i know a guy in IL that tunes lsjs
Old Apr 6, 2010 | 03:47 PM
Aaron-0703's Avatar
I know some people as well I just am trying to keep my warrentie so I just want the gm tune.. Rhys y I'm trying to find out if I can use the old one with the new authorization code
Old Apr 6, 2010 | 09:43 PM
06G85's Avatar
Hey man, I made a thread similar to this a while ago, and seems like every response I got beat around the bush like this thread is going.
Aaron-0703 - You can use the GM PCM that you got from the other car and it will work as long as you did what I said. As far as the authorization code in concerned; if the code has not been used, you can use it to get a tune. But if the PCM already has the Stage 2 tune on it, you don't need to get it flashed.
MT0911 - Haven't gotten it installed yet. I will tomorrow afternoon. I'm dropping it off at 2. I'll let you know tomorrow night! But someone else said they did the same thing I'm doing and it's working just fine. Also, noticed you have a hiflow cat. Did you throw any codes?? If so, what can I do to eliminate it? Angled O2 sensor? Where do I get one?
Old Apr 7, 2010 | 08:40 AM
MT0911's Avatar
To the OP, this info 06G85 provided is correct. Good Luck.
06G85- Sounds good with the stage 2 kit. You'll notice quite a difference from stock. Have fun with it . My sig is a little off right now, I have new modifications and some of the ones listed are no longer there. I actually don't have the Header/Downpipe/Exhaust setup in my thread anymore. I went back to stock (trying to save up money lol). But when I did have it I didn't throw any codes. I know some people do and some don't but I never had a problem. I even passed MD State Inspection with it. But if for some reason you DO throw a CEL, you have 2 options. Either get an angeled O2 sensor (Ebay has them very cheap), or you can get the code tuned out (probably won't do the tune but just letting you know that it's an option). Good Luck
Old Apr 7, 2010 | 10:40 PM
06G85's Avatar
So I goto the dealer to drop my car off and they beat around the bush oh well we can't do it today, can you bring it back next week. At first no one knew wtf a stage kit was and saying the don't install aftermarket kits because it'll void the warranty. I said, it's NOT aftermarket its a GM part dipshit!
So after discussing for 15 minutes, they said drop the car off TUesday night, they'll pay for a rental car for the first day, and i should get it back Wednesday night. WOO HOO YAY (sarcasm cough cough)
SO needless to say before I get any of this done, I need to find out how much they are going to charge me. They can charge anything...
Old Apr 8, 2010 | 12:28 AM
MT0911's Avatar
I actually got the GM Stage 2 kit for a pretty cheap price brand new. When I took mine to the dealer (a while back) they told me they have never done one either. So I spoke to management and let him know the deal and he told me to drop my car off and it took them 3 hours and I paid just under 250 in total for install. Good luck though, you'll be happy once the install is finally complete. It pulls nicely in 2nd and 3rd, a lot better than stock. Let me know how it goes.
Old Apr 8, 2010 | 01:07 PM
06G85's Avatar
This kit WILL void my warranty. I don't have an existing factory warranty anymoer (I have just over 36K miles) The kit does not void the factory warranty, but it does void my GMPP extended warranty.
ALL this time and effort to put together a stage 2 kit and still keep my warranty now means nothing...
Old Apr 9, 2010 | 12:35 AM
MT0911's Avatar
What? How does it void your extended warranty? Do you have that in writing? I don't understand how that is possible if under factory warranty GM honors the GM Stage 2 kit and includes it under warranty but under extended warranty they don't honor it. There has to be something wrong with that. So if someone decides to do GM Stage 2 while still under factory warranty and then when the factory warranty is up, they opt for the extended warranty, and they are disqualified because of something that was previously warranted? That doesn't sound right because technically GM Stage 2 is not aftermarket and GM states they do support it under warranty. What are they telling you?
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
