Rainy day Problem
Old Nov 27, 2011 | 06:49 PM
duffman11's Avatar
Rainy day Problem
When it starts to rain I get a problem with the balt. The more it rains the worse it gets. I don't drive through standing water, even if it just sits in a parking lot for 10 hours the problem still exists until the weather gets better...
Problem: Car isn't getting "quality" air, well I assume this is the problem. Only when it rains I am only allowed to go a certain amount of RPMs before she bogs down. I mean really bog down, Wide band will jump from 10-16 about 9 times and once I let off the throttle it normals out. This has happened the last 3 rain storms we have had. Anyone else experience this issue? I just order the Hydrashield for the Injen intake. hopefully that will help solve the problem.
Old Nov 27, 2011 | 07:36 PM
volsfan92's Avatar
My wideband goes crazy but car normally feels ok... it has bogged a few times but that was a maf sensor prob
Old Nov 27, 2011 | 07:40 PM
damastah's Avatar
this happened to me when i had an injen CAI.
once i put the Turbo XS CAI, i go WOT in ******* hurricanes... no problem. car pulls hard.
Old Nov 27, 2011 | 07:49 PM
mikej's Avatar
its probably because you are using an oiled air filter....remember oil and water dont mix and they will cause major MAF sensor problems
Old Nov 27, 2011 | 07:58 PM
sick_tight's Avatar
never had a problem with my Injen EVER
Old Nov 27, 2011 | 08:59 PM
duffman11's Avatar
Car does bog down. REALLY BAD...
I don't think it's the actual "intake"
Water / oil only mix when you dink a glass after the girl uses oils to give me a massage
Should I clean the TB out? It's going to get reaplced by LS4 in a half a year. I'm hoping not to drive in tomany rain storms. Will the Hydro shield help?
Old Nov 27, 2011 | 09:03 PM
08SSTCRD's Avatar
Don't rule out an ignition issue, could be losing spark from moisture in near the coils and boots. Check both the coils and boots for signs of moisture and look for any cracks in the rubber or plastic of the housings.
Old Nov 27, 2011 | 09:18 PM
ULWizSS's Avatar
Gonna put my finger on a maf issue throwing the pcm off.
Old Nov 27, 2011 | 09:19 PM
duffman11's Avatar
That was the 2nd thing I checked. I had a similar problem with my Mustang. Water was getting past a hose it shouldn't.
Old Nov 27, 2011 | 10:23 PM
metzO7's Avatar
I had a similar problem when my engine was cold but it ran fine when it warmed up so I took my injen airfilter off and there was water dripping off the maf sensor, I was afraid of having this problem so I avoided all standing water but it still happened. I discovered that the water was getting in between the wheel splash shield and the body, used some duck tape and plati dip and sealed it up no problems since. I know this isn't a permanent solution but removing the cai every time its going to rain would suck. Hope this helps ya out
BTW I have heard of ppl having problems with injen's oiled filters but this is the only problem I've had in the 4+ months its been on... Not a single Check engine light
Old Nov 28, 2011 | 12:40 AM
damastah's Avatar
im telling you. same thing happened to me with the injen intake..
but all of a sudden went away when i put the turbo xs intake on...
you're saying its the not intake?
Old Nov 28, 2011 | 12:49 AM
Chevycobaltss3's Avatar
I don't car if u have a airbox or a Cai with or without hydrashield.this. should be Ure first step when diagnosing issues when rain or humidity occurs. U can be sucking up water / humidity and it'll hit the maf. Causing it to go rich or lean ......
Old Nov 28, 2011 | 01:24 AM
damastah's Avatar
idk dude... the location of the injen intake is too low.
Old Nov 28, 2011 | 01:29 AM
duffman11's Avatar
I do think everyone seems to agree it's the MAF getting wet. I'll take a look at it next time Ima run her in the rain and pull into a garage and take it apart. Ima toss on the Hydrashield and see if it helps resolve the problem. Car already runs rich, Air intake, header, DP, and exhaust, with no tune. BTW SS3 you ever tune a TVS before?
Old Nov 28, 2011 | 10:14 AM
Lol... Ummmm..... Yes ..... Why u ask?
Old Nov 29, 2011 | 12:54 AM
red06SC's Avatar
Actually, you've got it backwards. Oiled filters will repel water, Injen intakes used to come with oiled K&N style filters - I believe they now come with dry synthetic filters.
OP if you have the new Injen you should switch to a proper oiled gauze filter or get a hydroshield.
Old Nov 29, 2011 | 05:23 AM
ULWizSS's Avatar
I had maf issues starting last winter for some reason. I was logging when this happened as well. Was driving down the road no rain or snow and the car would drive normal. All of a sudden it would start to snow and the car would almost instantly start bogging and act crazy. Could barely give it any gas, actually had to pull over constantly and attempt to get it started again. AFR all over the place and the maf sensor was going horribly up and down.
Took two sensors and making sure it was sealed up nice underneath to fix my issue. Slapped a new finger on it as well.
Old Nov 29, 2011 | 07:40 AM
Cherry GT's Avatar
I washed my car the other day with no front bumper on and boy was I suprised what I saw !
Water runs down a channel in the unibody by the hood and comes out the cutout pictured.
It pours out alot of water right where the air filter is in the wheel well.
CAN'T BE GOOD !
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
maliki778
Oct 1, 2015 07:39 PM
Extremespeed
Sep 29, 2015 04:34 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
