brought the gm performance header to be installed
the mechanic said thats the same header than stock. did i get ripped off? the guy said it was gm performance header. can i have a picture of the stock one and the gm performance.?
another thing is i noticed some buzzing in my exhaust afterwards (im still fully stock)
The GMPP Extrude Honed Manifold is essentially a ported stock manifold.
Look at the inside of the manifold. If the runners & collector are smooth you are ok.
If there are rough castings you got ripped off.
ohhh so it looks exactly the same ok. then thats probably why the mechanic was like well thats the same part. but mine had a crack in it so im glad its changed anyways.
what should i expect for performance on everything else stock?
It flows 30 CFM more than stock. A member dyno'd one back in the day and gained 4whp & 6wtq.
Here are some flow numbers to back up Staged's post:
Hi ! Here are my flow calculation for some LSJ engine parts :
ADDED COMMENT : These flow numbers are calculated at ambiant air temperature AND pressure.
Stock Throttle Body (67 mm) : 625 CFM.
EDITED : Stock Head : One intake port : 250 CFM @ stock 0,395" valve lift. One exhaust port : 145 CFM @ stock 0,395" valve lift. Stock head is said by GM to be efficient up to 275 WHP; it is clearly possible to make more WHP than that, but in a unefficient way (several HP losses caused by heat and restriction).
Stock Exhaust manifold ("Header") : 425 CFM.
Stock Downipe (DP) with cat : Plus or minus 370 CFM or less.
Stock Cat-back Exhaust (2,5" inlet to 2,25" outlet with stock muffler) : 300 CFM.
Now here are some replacement parts :
GMPP Exhaust manifold ("Header") : (30 more CFM than stock) : 455 CFM.
Shorty or long tube Header with 1,75" primaries and 2,5" outlet : at least 500 CFM.
Shorty or long tube Header with 1,75" primaries and 3" outlet : at least 725 CFM.
Shorty header with 1,5" primaries and 2" outlet : Waay not enough, who cares LOL.
Stock DP w/o cat : 425 CFM.
2,5" DP with VERY HIGH FLOW cat : plus or minus 450 CFM.
2,5" DP w/o cat : 500 CFM.
2,75" DP with VERY HIGH FLOW cat : plus or minus 475 CFM.
2,75" DP w/o cat : 600 CFM.
3" DP with VERY HIGH FLOW cat : plus or minus 500 CFM.
3" DP w/o cat : 725 CFM.
Stock catback with only the rear muffler replaced (the last portion is still in 2,25" tubing) : 350 CFM.
Stock catback with last portion replaced for 2,5" tubing and straight through muffler : 450 CFM.
2,5" catback : From 450 to 500 CFM (must be a straight through muffler).
2,75" catback : From 550 to 600 CFM (must be a straight through muffler).
3" catback : From 650 to 725 CFM (must be a straight through muffler).
Hope this can help ...
Regards
Regards
woah thanks pyro!!!
wow only changing that 2.25 section really opens it up!
well with that in mind... all i need is that highflow cat downpipe, and that 2.5 over axel and then i already have a magnaflow glasspack straight muffler. what do you guys think?
So you would want to replace the stock resonator as well (if you don't want to purchases a full catback exhaust).
