ran compression tonight
Old Feb 1, 2008 | 09:23 PM
boostnss's Avatar
#1-160
#2-160
#3-170
#4-170
if i blew a intake gasket can coolent get into the head that way?
Old Feb 1, 2008 | 09:32 PM
Red2.4SS's Avatar
If something is leaking with the intercooler cores it could pull coolant into the intake air that way.
Old Feb 1, 2008 | 09:34 PM
boostnss's Avatar
maybe i need to look in to that then. thanks for the info
Old Feb 2, 2008 | 02:29 AM
Area47's Avatar
Rent me! per hour
numbers seem low for some reason. however they are withing a certain percentage of each other to be cool.
do you have chocolate milk in the pan? pull the radiator resivoir cap off and let the car warm up. check for bubbles that don't stop. this is a simple check. hell do a leak down, this will give some what of a better answer.
what makes you think it's toast?
Old Feb 2, 2008 | 06:53 AM
boostnss's Avatar
i havent changed the oil yet, i will try to do a leak down test today, the only thing i got to do was a compression test because i use my firends shop and he works nights so i had limited time there last night he is off to night. i don't know if is toast of not it was really milky under the oil cap that is about it.
Old Feb 2, 2008 | 09:50 AM
Red2.4SS's Avatar
That white milky sludge is a sign of water in the oil!!!
DO NOT DRIVE IT!!!
You may have a blown head gasket.
Check the coolant reservior for bubling as Area said. Has your coolant been dissapearing?
Any unusually high amout of exhaust steam, even after fully warmed up?
I would also reccomend the leakdown test.
Old Feb 2, 2008 | 01:12 PM
boostnss's Avatar
DO NOT DRIVE IT!!!
no coolent is good and no white smoke and it compressed fine, going to change the oil and check for bubbles today.
Old Feb 2, 2008 | 01:20 PM
Area47's Avatar
Rent me! per hour
m-dubs car has the same issue. his car is fine. it doesn't get hot, or do anything stupid. it has to do with condensation. being that we in the midwest suffer from irratic weather changes. water is bound to find it's way into weird places.
Old Feb 2, 2008 | 01:53 PM
zrated89's Avatar
170 is kinda low though, when i popped my oil dipstick out (i dont think i snapped it down all the way) everyone said do a comp test i did one at my shop and had over 200psi in all cylinders
Old Feb 2, 2008 | 01:56 PM
Witt's Avatar
#1-160
#2-160
#3-170
#4-170
No, thats pushrod engines. No coolant in our intake manifolds outside of the supercharger's coolant system. I wouldn't worry about it until you see foam on the dipstick.
Mine pulls about 190psi with 10-1 compression pistons. Wes' was ~165 iirc with stock ones.
Old Feb 2, 2008 | 02:34 PM
boostnss's Avatar
so is my compression fine? some people are telling me 170 is low others say it's fine.
Old Feb 2, 2008 | 02:45 PM
lnf08ecotec's Avatar
its fine; they are all near e/o...and if they were all low...u'd definately know it......
Old Feb 2, 2008 | 02:56 PM
Rippin07's Avatar
The white milky crap under your cap is most likely condensation. This occurs mostly when the weather gets cooler and more often than not the car is driven on short trips. The condensation in the motor evaporates and rises to the top of the engine (valve cover) and settles on the cap etc, as the engine cools it condenses into the milk you see. Your car is fine, this is a normal thing to happen when the weather cools down.
Old Feb 2, 2008 | 03:09 PM
boostnss's Avatar
i want to thank everyone for the help. i guess i shouldn't jump to conclusions with out doing tests first.
Old Feb 2, 2008 | 03:26 PM
hungryhip-ccp's Avatar
mine were all 140ish and the car was brand new when i did mine... it had 1600mi on it maybe my gauge was wrong... alldata says there all supposed to be over 100psi so i dont know how you guys are seeing allmost double stock specs
Old Feb 2, 2008 | 03:28 PM
Area47's Avatar
Rent me! per hour
i have tested mine twice. two different gauges. same results.
200 across the board.
::shrugs:: got me d00ds
Old Feb 2, 2008 | 03:30 PM
Sharkey's Avatar
alldata states the minimum is 100psi, but really thats too low.
i know my buddys l61 is 160 with aftermarket cams, and thats 10:1 compression.
Old Feb 2, 2008 | 03:31 PM
bigjoe25's Avatar
mine were over 200 in cylinder 1 and 4 and 115 in 2 and 100 in three but i had two cracked pistons
Old Feb 3, 2008 | 11:00 PM
Red2.4SS's Avatar
I thought you were talking about the oil itself being milky.
A little on the cap is normal as stated above.
There is always some moiture in the engine from the small amount of normal blowby, that is harder to get rid of when its cold.
hacadacalopolis
Oct 28, 2015 06:09 PM
Tupp
Sep 30, 2015 08:18 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
