Rebel 3.5" TB Dyno Results
You guys ask and we deliver, so here are the results:
Vehicle Specs (before 3.5" TB):
2007 SS/SC
GM Stage 2 with 3" pulley
GM Honed manifold
GM Cat back exhaust
Rebel 3" Stainless Intake
Below you will see the before and after, the blue lines are before and red after.
Summary: Down low (3350rpm) we produced 11WTQ and 7WHP
Mid range (4000rpm) we produced 8WTQ and 6WHP
Top end (6000rpm) we produced 12WTQ and 14WHP
Notes:
1. The only thing changed in the tune was the idle air flow ETC scaler area, no fueling or spark settings were changed.
2. The install as you can see took less than 24 minutes as you can see the dyno runs are 24 minutes apart.
3. With the above mods (before the new TB) we only produced 219WHP showing how our dyno reads lower numbers. But the beauty of it is the difference is accurate. Now compare this to the Twin Screw numbers 281WHP produced on the same dyno in the middle of summer (hotter temps).
4. The air/fuel went low 10's after 6000rpm which we expect from the GM Tune. There is plenty more power to be made here with some tuning.
People who have installed this upgrade:
"ok so i got this tb upgrade done today. i can now attest to this being an AWESOME F'ING UPGRADE! we dynoed somewhere from 10-15whp gain in the lower rpm range (below 3G) and somewhere from 10-20 lb ft gains. this isn't one of those mods where you find yourself debating whether you actually feel any difference either. you notice the difference right away. it pulls much harder and much sooner on the low end and this is exactly what the cobalt needed because it was lacking on the low end. now it feels awesome! i'm so glad i did this and i give much props to rebel for another fine upgrade! cheers guys!"
"ill tell you right now throttle response in like no other cobalt ive driven b4 with the stock charger. its almost impossible to drive this thing slow since no matter what rpm you are in a slight touch of the gas the the car darts forward, first gear is that much more usless now lol. stomp in any gear and it pulls alot harder than what it was liek b4 all the way to redline. its a amazing mod to compliment all the other modifications i have to my car."
The 3.5" TB and spacer GB will end tomorrow!
Data Log Results:
Without New TB:
Boost 15.47 PSI
MAF 31.57 LB/MIN
With New TB:
Boost 15.62 PSI
MAF 31.57 LB/MIN
So basically you don't see much of a difference top end in flow numbers.
The 3.5" TB and spacer will end tomorrow!
On the list:
1. quadracer0387
2. Sunburst_SS (with intake)
3. Toyotech
4. IamTvor
5. joselo6
6. lsjwannabe
7. Boossted
8. ninja44
9. silentd
10. Area47
11. RedSSBaltSC
12. Coop
13. Rodimus_Prime
14 & 15. r0k0 (with intake no filter) (another spacer with 1/8" npt for meth)
16. 607Motorsports
17. my_bd
18. RG4
19. Freakenhye
20. Hockeyman0920
21. burntorange
22. Jumpin Fool (with intake polished)
23. Stihl (with intake)
24. SS/SC05/19/05
25. K-Train04RL (with intake)
26. Omega_5
27. darksol4life (with intake)
28. Blur.fx (with tap for meth)
29. WolfmanKiknAzz
30. kanabrewski (1 intake 2 spacers with one tapped)
31. SSKobald (2 spacers with on tapped)
2007 SS/SC
GM Honed manifold
GM Cat back exhaust
Notes:
Data Log Results:
Without New TB:
Boost 15.47 PSI
MAF 31.57 LB/MIN
With New TB:
Boost 15.62 PSI
MAF 31.57 LB/MIN
On the list:
1. quadracer0387
3. Toyotech
4. IamTvor
5. joselo6
6. lsjwannabe
7. Boossted
8. ninja44
9. silentd
10. Area47
11. RedSSBaltSC
12. Coop
13. Rodimus_Prime
16. 607Motorsports
17. my_bd
18. RG4
19. Freakenhye
20. Hockeyman0920
21. burntorange
24. SS/SC05/19/05
26. Omega_5
29. WolfmanKiknAzz
well you need to use the 3.5L colorado TB
at the say time... you can find this throttle body on numerous vehicles:
COLORADO 04-05 Throttle Valve Assm; 3.5L
ENVOY 05 Throttle Valve Assm; 4.2L
TRAILBLAZER 03-05 Throttle Valve Assm; (4.2L)
HUMMER H3 06
BRAVADA 03-04 Throttle Valve Assm; (4.2L)
ENVOY XL 03-05 Throttle Valve Assm; 4.2L
ENVOY 03-04 Throttle Valve Assm; (4.2L)
IMPALA 06 Throttle Valve Assm; 5.3L
ISUZU ASCENDER 03-05 Throttle Valve Assm; 4.2L
GRAND PRIX 05-06 Throttle Valve Assm; 5.3L
ENVOY XUV 04-05 Throttle Valve Assm; 4.2L
TRAILBLAZER EXT 03-06 Throttle Valve Assm; 4.2L
CANYON 04-05 Throttle Valve Assm; 3.5L
MONTE CARLO 06 Throttle Valve Assm; 5.3L
TRAILBLAZER 06 Throttle Valve Assm; 4.2L
RAINIER 04-05 Throttle Valve Assm; 4.2L
SAAB 9-7X 05-06 6 cyl
HUMMER H3 06
