Rebel Auto Worxs Turbo Kit Group buy
Old Aug 23, 2007 | 08:06 AM
djt81185's Avatar
Originally Posted by Sales@rebelautoworxs
Hey guys Thought we would Bring another one of our products to the table.
We are trying to get 4 kits for this Group buy.
Our stage One kit has Made 325whp and 290wtq on 18psi
I'll have some updated Numbers as were headed to the dyno to better those numbers
We have a Few different options .
Rebel Auto Worxs Stage 1 Turbo kit
Precison Turbo T-3 turbo Rated at 450hp Journal Bearing turbo.
Stainless Steel turbo manifold with 38mm external Wastegate
Tial 38mm Wastegate.
Choice of Apexi BOV or Tial 50mm Bov.
Stainless Down pipe with no Cat
38mm wastegate dump tube
Custom Intake intake Piping
Intake Plenum to connect to stock lower manifold.
Custom Idler setup
Billet dual pass Endplate
Stainless steel T bolt Clamps
Assorted silicone Couplers
Oil Feed and return lines
Air filter assembly
Assorted hardware/ vacuum lines
Price $3399.99
Stage 2
Rebel Auto Worxs Stage 2 Turbo kit
Custom Idler setup
Air filter assembly
Front Mount Intecooler
Additional cold side Piping.
Price $4099.99
Rebel Auto Worxs Stage 3 Turbo kit
Custom Idler setup
Air filter assembly
Fabricated Aluminum sheetmetal lower manifold with Velocity stacks.
Higher flowing and less restrictive unit.
This Kit is custom and can only be ordered at the same time.
Price $4899.99
Video
http://www.youtube.com/watch?v=0hSPFa0bE44
Upgrades and add On's
Garrett Gt2871rs 440hp Ball bearing turbo $425.00
Garrett Gt30rs 500hp Ball bearing turbo $625.00
Add highflow cat to downpipe $125.00
Tune File $250.00
Manual boost controller $60.00
Those prices arent too bad considering what you get. Especially the stage 1 imo. Tho...why are u air to air intercooling it in stage 2. Then why are you completely removing the lower intake manifold in stage 3 and still including the billet dual pass plate.
Lastly is this a blow thru or draw thru setup.
Old Aug 23, 2007 | 08:53 AM
Sales@rebelautoworxs's Avatar
Fixed the Error.
We have figured out the tune for it being blow throw maff on the the pressure side.
Old Aug 23, 2007 | 09:10 AM
djt81185's Avatar
Fixed the Error.
You have that HPT log of it still. I wanted to look at your maf frequencies.
Old Aug 23, 2007 | 10:53 AM
Luv2Race's Avatar
Come on everyone jump in on this deal, I know im in for sure.
Old Aug 23, 2007 | 11:10 AM
Rangerondubz's Avatar
I will be your 2nd test vehicle! lol
Old Aug 23, 2007 | 11:13 AM
pimpnwink's Avatar
Damn i hope i can get enough money by they time this deal is over so far i only have around 2k and i want the custom kit. Heres hopeing .
Old Aug 23, 2007 | 11:14 AM
No testing needed on this one. Can i add you
We've have a customer that has been running this kit for 6 months now with Zero Issues!
Other than than killing his clutch in a week.
Old Aug 23, 2007 | 11:37 AM
QuikSilverSS's Avatar
Does the Kit come with 60lb flow matched injectors?
Old Aug 23, 2007 | 11:42 AM
60lb injectors are not included. You can get your own or we can provide flowmatched 60's and a harness for $260.00
Old Aug 23, 2007 | 01:05 PM
Jmc007's Avatar
You could use a Mini AFC 2.2 (in advanced mode) to let the PCM think you make less than 12 or 13 000 Hz while in fact you make more.
What are the main differences between the GT2871RS and the GT30RS if both are running with the stock head and 3" downpipe and 3" exhaust ?
Old Aug 23, 2007 | 01:10 PM
  #36
Max Power and spool up times. Although you can help spool up times with fueling and timing changes to an extent.
You'll be able to go father with the Gt30r. Spool time with be affected but no too bad.
Old Aug 23, 2007 | 01:11 PM
  #37
Onyxd04Redline's Avatar
I'll offer this up for a month at this point.
The Difference with our kits and Hahns Kits We use much higher quality parts
They use a 16g turbo-we use garrett and precison turbos
They use mild steel for all there piping We use Stainless steel
They use rubber couplers We use 4 ply re-enforced silcone.
They use gear clamps We use Stainless t-bolt clamps
They connect to the stock downpipe We make Our own high flow downpipe.
How is that for a comparision?
Site states they use a Garrett GT2860RS turbo. "Shrugs" It's all good
Old Aug 23, 2007 | 01:26 PM
  #38
KillerBee's Avatar
Originally Posted by turboeco
C'mon Rebel! Someone drops 3k+ on a kit from you, twinscrew or turbo and you won't throw in a tune!?!?
I think its BS to see you charge $250 for the tune. If I'm dropping a couple grand on a kit, the least you could do is throw in the tune.
Hey man this is from the rules on this site
"Do not bash our Supporting Vendors. They help us keep the site running!"
Old Aug 23, 2007 | 01:28 PM
  #39
WSFrazier's Avatar
If you are going as far as swaping a snail into your car, you should be knowledgable in how to tune it yourself. Or else you probably shouldn't get this.
Old Aug 23, 2007 | 01:53 PM
  #40
Why? It's easier to pay someone who's an expert at it to do it.
Old Aug 23, 2007 | 04:14 PM
  #41
Luv2Race's Avatar
So who else is going to be purchasing a kit?????
Old Aug 23, 2007 | 06:54 PM
  #42
chucktheweasel's Avatar
Wow, you guys are releasing the turbo kit already?! Nice!
And to whoever said $250 for a tune is pretty high, I don't think it's that bad at all. It takes them so long to get tunes dialed in. Other places probably charge twice that.
Keep up the great work guys!
Old Aug 23, 2007 | 07:42 PM
  #43
SSMOKEM's Avatar
If my loan gets approved tomorrow I'll be in on this
Old Aug 23, 2007 | 08:52 PM
  #44
Luv2Race's Avatar
Come on guys this is a GREAT deal....... I already put my money down on it so they can start putting my kit together. Lets see some more people getting in on this.
Old Aug 23, 2007 | 09:16 PM
  #45
Johnny B's Avatar
what other mods will you need for the stage 1? for example: pistons, clutch, alxes, and ???
what psi will this produce? how hard will the install be? do you have anymore pictures?
i would like to know more info...
thanks
Old Aug 23, 2007 | 09:24 PM
  #46
Luv2Race's Avatar
thanks
Their test vehicle I beleive was just running a 3" exhuast and probably a clutch upgrade, and had stock internals running aroun 18-19psi. Jim correct me if im wrong on any of this.
Old Aug 23, 2007 | 09:30 PM
  #47
Eng@RebelAutoWorxs's Avatar
correct
a clutch is a must, axles you might be ok with as it's easier on them off the line, 3" exhaust is a good idea
Old Aug 23, 2007 | 11:30 PM
  #48
1gmfanatik's Avatar
I would LOVE to get in on this kit, but I have to pay into my credit card first. lol...
Keep up the good work guys, waiting to see much more good things from ya'll
Old Aug 24, 2007 | 09:35 AM
  #49
Luv2Race's Avatar
Lets see some more poeple throwing down some money on this kit!
Old Aug 24, 2007 | 02:54 PM
  #50
2K5SS/SC?'s Avatar
Luv2Race, when I'm done with the TS, maybe we can meet up for a little Rebel Auto Worxs kit comparison run. I think that would be fun for us and the guys on the site.
