red tip spark plug???
Old Mar 26, 2009 | 04:18 PM
  #76
MBMCustoms's Avatar
Originally Posted by Hockeyman
Did you use Marc Heitz to change your fuel filter? I'm due for one soon, wondering how much they will charge me. Also the O'Reileys near me has BKR7E's in stock so you don't have to order them next time.
no got one at autozone and did it myself. its too simple for 15 bucks and thanks for the info on the plugs. how much do they run at o'reallys?
Originally Posted by slowswap
Try to stick to better gas stations like BP, Sunoco and Mobil.
what sucks is i dont have any of those near me
Last edited by MBMCustoms; Mar 26, 2009 at 04:18 PM. Reason: Automerged Doublepost
Old Mar 26, 2009 | 04:39 PM
  #77
arkkornkid's Avatar
it may very well be fuel additives: Refineries make a Summer and a Winter blend. It could just be what's in the winter blend causing the discoloration. I don't think the summer blend has gone into widespread distribution yet.....and probably won't hit the northern states till mid-April/early May.
Old Mar 26, 2009 | 04:51 PM
  #78
malckom's Avatar
The coolant you might have a head gasket leak
Old Mar 26, 2009 | 05:17 PM
  #79
Area47's Avatar
Rent me! per hour
uh no.
Old Mar 26, 2009 | 05:19 PM
  #80
BLAZIN07SS's Avatar
I'm too JDM for you
no
Old Mar 26, 2009 | 05:28 PM
  #81
Hockeyman's Avatar
ah nice, i may do that this weekend then. There are plenty of Shells and Chevrons near us, start using them. How did your old filter look?
Old Mar 26, 2009 | 05:35 PM
  #82
blackbird's Avatar
Coolant when burnt will leave whitish residue/deposits. The red is from the MMT or possibly another additive in the fuel. As a side note, if you're ever trying to diagnose a fueling issue such as an injector, you can put in a bottle of the cheap octane boost with MMT and drop in a new set of cheap plugs. Then drive the car for a few WOT pulls and pull the plugs. If one has a lighter red tint you'll know that cylinder is running leaner. It's not as good as per cylinder EGT probes but can be handy for quick troubleshooting.
Old Mar 26, 2009 | 06:21 PM
  #83
BCM's Avatar
BCM
I've always used 7-11 gas and my car runs just fine.
Old Mar 26, 2009 | 06:24 PM
  #84
Hockeyman's Avatar
why do you guys use such shitty gas? My car only sees shell or chevron, same price too.
Old Mar 26, 2009 | 06:29 PM
  #85
BCM's Avatar
BCM
I've never noticed any difference when I use other gas. I'm about to have to fill up soon, maybe I'll try out Shell.
Old Mar 26, 2009 | 06:34 PM
  #86
recklessactn's Avatar
i use a 7 elevens gas because it is the closest station that doesnt use ethanol.
ewww 7 eleven gas
Old Mar 26, 2009 | 06:57 PM
  #87
sport08's Avatar
Originally Posted by recklessactn
ewww 7 eleven gas
x2 thats some **** gas i use shell, exxon, and hess(rarely)
Old Mar 27, 2009 | 01:49 AM
  #88
MBMCustoms's Avatar
i just filled up with shell today so i will see how that goes. waiting on my new plugs then i can actually see if anything has changed
Old Mar 27, 2009 | 07:25 AM
  #89
Staged07SS's Avatar
Administrator
Administrator
Sunoco Ultra 93 .... Love it !!!!
Old Mar 27, 2009 | 02:26 PM
  #90
MBMCustoms's Avatar
once again..... wish i had it here
Old Mar 27, 2009 | 07:08 PM
  #91
BCM's Avatar
BCM
I just discovered that the Shell nearly 4 miles from my house has 93 octane. Looks like I found a new place to fill up! Just wish I knew that a long time ago.
Old Mar 27, 2009 | 07:11 PM
  #92
arkkornkid's Avatar
yeah...I go about 5 miles out of my way to hit up a particular Shell for the 93..there are 2 others nearby, but all they have is 91
all I ever ran in my Cobalt was Shell, same for my S now
Old Mar 27, 2009 | 10:25 PM
  #93
sport08's Avatar
all i ever have run in my car is 93 i dont know anyone around who doesnt sell 93
Old Mar 30, 2009 | 01:32 AM
  #94
MBMCustoms's Avatar
i have been using shell 91 lately, changed fuel filter, changed intercooler pump, and changed out plugs to ngk step 1 coolers. i gapped the plugs at .040 and now i only hit 15psi. should i play with the gap till i find the best set-up or can anyone tell me anything that could help me. car runs great now and no red plugs again (yet *praying for the best*).
Old Mar 30, 2009 | 07:41 AM
  #95
Staged07SS's Avatar
Administrator
Administrator
0.040 is to large for a modded SS/SC. I know in the manual they say 0.039, but mine were gapped at 0.035 from the factory and the car runs fantastic. Each car takes to a certain gap diff. .... You have to experiment with it, and see what your car responds to best.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
