to remove exhaust, does it have to be cut?
do i have to cut the exhaust in order to take it off? or can i just take it off.
i want to put on a cat back, downpipe and headers so it all has to come off
can someone let me know if i can take it off without cutting it. because i dont have anything to cut it
iman expert now after getting yelled at by everyone on here. hahah yea basically cuttit whever u want just so u can slide the old exhaust outt but tomake urelife easier right above the axleor a little in front of it
ask anyone for a sawZAWL cuts through like butter
Remove the lower shock bolt on the passanger side. The 10mm on the brake hose and put a jack under the axle. It comes down far enough. I did it on a lift so it could be hard and it was last year so i dont remember. But you answer your question no you dont have to cut the exhaust unless you want to be a lazy hack. I like to keep all my stock parts.
if you have access to a lift you dont need to cut it. you have enoungh room after lowering the pass side shock and brake hose ,mensioned above. if you dont have a lift it will be more than those two pieces being removed. there is nt enough room to swing it on the ground
I was able to get mine out with one cut with jackstands
