Removing valve cover... please help
Old May 3, 2007 | 06:11 PM
chevysalesman614's Avatar
I'm planning on painting my valve cover since my car is all taken apart.. (porting blower, and polishing the outside). can i take it off w/o replacing the gasket?
Old May 3, 2007 | 06:19 PM
chevysssc's Avatar
every time you take something like that apart you SHOULD REPLACE IT
Old May 3, 2007 | 06:26 PM
thats not what i asked.. I've taken other things off and the gasket was fine.. like the blower... but did they use any liquid gasket when they put the valve cover on?
Old May 3, 2007 | 06:33 PM
Mikey851's Avatar
Yeah, it's exactly what you asked. The answer is; everytime you take something off you SHOULD replace it. As in, you don't have to, but you should because it might cause more problems than it saves you money in the long run.
Old May 3, 2007 | 06:34 PM
spaz's Avatar
I reused mine with no problems.
Old May 3, 2007 | 06:35 PM
Sunburst_SS's Avatar
no, the gasket is a rubber gasket...as long as you don't damage it it will be fine. I removed mine and polished it a few weeks ago.
Old May 3, 2007 | 07:42 PM
Halfcent's Avatar
I'm old school
The valve cover gasket is neoprene rubber. Completely reusable over and over as long as you don't tear it. It will be glued to your valve cover and will stay attached to it
Old May 3, 2007 | 07:45 PM
thanks halfcent
Old May 3, 2007 | 10:49 PM
IMADreamer's Avatar
As others have said yes it is reusable. I've taken mine off twice now and I haven't changed the gasket and I have no leaks.
Old May 3, 2007 | 10:52 PM
Mikey851's Avatar
I have reused valve cover gaskets as well because it's a low pressure area and therefore will not usually have any problems.
That's cool that our gaskets are made of neoprene; that is much better than the cork gaskets which are the ones that I would replace if I removed it.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Trav3480
Sep 28, 2015 02:46 PM
