return fuel system
Old Jul 10, 2008 | 11:06 PM
racehtecobalt's Avatar
return fuel system
what exacty is the return fuel system and what do u benefit....and what does it help or prevent.
Old Jul 11, 2008 | 09:52 AM
rrutter81's Avatar
prevents draining the #4 piston out of your oil pan next change.
Old Jul 11, 2008 | 10:34 AM
Pully Police's Avatar
A return fuel system provides a return path from the fuel rail / regulator back to the fuel tank.
The benefits are that you can adjust base fuel pressure to allow more range with your fuel injectors, you can have the regulator referenced to manifold pressure - this will ensure that fuel is being injected at base fuel pressure in reference to manifold pressure. (base pressure = 50psi, manifold pressure = 15psi, Therefore - fuel will be injected at 65psi - same goes when you are operating in negative pressure). Tuning wise, this allows you to flatline your IFR curve and eliminate alot of the "gray" area in fuel tuning.
Old Jul 12, 2008 | 12:31 AM
wow....thanks a million
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
ashalle2
Sep 27, 2015 03:28 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
