Return style fuesl system!
I am just curious as to if this system is really needed, and for what goal of hp? I am thinking I may need this because I am looking for 400hp or so. Also what size injectors would one suggest I run?
Alright I have the Hahn level V kit. I have diamond pistons, nuetral balance shaft, cometic head gasket, arp head studs, port n polished head w. 3 angle valve job, aftermartket valve springs seat n retainers, set of cams,and a stage 3 clutch, and right now i only have to 60lb injectors which without having the car tuned for boost just for drivability their ok but im afraid one we actually fully tune the car ill def be maxing those out and wondering if yall think i should run the return style fuel system.
80# injectors would be a better alternative from a plug-n-play perspective, especially since Omega and Redline4 released their handy injector offset spreadsheet. Redline4 also has plenty of experience tuning Hahn Level 5 w/ 80# injectors if you need help getting it set up.
I would also like to get my hands on this as well. I am most likely going to be needing the 80lb injectors for my setup.
Most people don't bother with the return style, so I never bothered mentioning how to do it.
http://www.*******************/forums...6142#post16142
