The right spark plugs to run with the Harrop?
Old 02-22-2009, 11:53 AM
Rodimus_Prime's Avatar
Ok i've tried this before with failed results, currently im running NGK BKR6E which is stock heat range and its a copper plug I'm also running .040 gap.
I've tried BKR7E plugs at gaps anywhere from .035 to .045 and I got knock in every gear under load, whats the right plug and gap for this setup??????
Old 02-22-2009, 12:13 PM
lsjwannabe's Avatar
I ran 25 psi on that plug to the tune of 22* once i went to 28 psi it started to blow out in 3rd i tried 2steps colder iridium and the same thing happen so i ended up pulling some timing for pump gas. Those plugs should handle your power just fine.
Old 02-22-2009, 12:30 PM
HOT CARLS SS's Avatar
Try the BKR7EIX iridium plugs 1 step colder. I gap'd them at .028-.030 with a 2.7 pulley runs awesome no spark blowout! I have friend with hybusa motor bikes with turbos and they run in the low 8sec range...they swear by the NGK iridium plugs thats all they use.
Old 02-22-2009, 01:15 PM
Rent me! per hour
Area47's Avatar
im running the 2.75 pulley right now on the 7e's gapped to .028. max timing is 21.5-22 degree's i think
zero knock from 40-150mph
Old 02-23-2009, 09:26 AM
so stick with the BKR6E?
Old 02-23-2009, 09:48 AM
SSdan's Avatar
Bkr7's. Close the gap. You have them open too much.
Old 02-23-2009, 09:51 AM
shabodah's Avatar
He definately has them too open, but at 6e with a 30 gap should work pretty well for anyone with decent support for their HTV1320s. That is assuming he is still running gasoline as a fuel, of course.
Old 02-23-2009, 09:53 AM
SCBLKRL's Avatar
7e's gapped down at either .32 or .30. Don't remember right off hand. No knock
Old 02-23-2009, 04:40 PM
ah ok ill give that a try
DarrenGC
12-24-2021 01:55 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
717ssbalt
10-02-2015 04:01 PM
dieGone
10-01-2015 06:27 PM
CobaltSS 16
09-29-2015 01:53 PM
Quick Reply: The right spark plugs to run with the Harrop?
