rough idle on stock 07 ss/sc
just as the title says, i have a 2007 SS SC and it has had a rough idle for about 3 months now. i have taken it to the dealer for this 3 times, theyve replaced the evap canister purge solinoid, catalitic converter and all 4 spark plugs. and it is still rough. its very lopey as if it was a 454big block with a blower and huge camshaft. does anyone else have a problem like this?
thanks
adam
thanks
adam
Mine did that for a little while when I first got it last summer, but it cleared up shortly. It did it the worst when I'd first get in it at the end of the day after it sat in 100+ degree heat, but I don't think you have that problem. Is it really bad and consistent? I mean mine will "rumble" every once in a while, but not very often. I think these cars typically have a fairly rough idle compared to other 4 cylinders.
FYI-dont ever get poly engine/tranny mounts if the rough idle bothers you now.
it only happens after the car warms up. and its like a bup bup------bup bup bup-----------------------------------------------------------------------bup --------------bup bup -----------------
