Running rich
i wouldnt think it would. did you take it out and run the ***** off of it? or did it do it on startup after pulley swap?
nm. reading > me. did you accidently unplug anything doing the swap?
cant hurt, unplug it for 15 minutes plug it back in, and let the car relearn everything
if your just swapping pulley's you didnt need to unplug anything..
Sounds like you forgot to plug something in possibly
Last edited by bgbearcatfan; Apr 22, 2008 at 08:38 PM. Reason: Automerged Doublepost
I unhooked the battery, and it still does it. The exaust is black soot and stinks like gas. I checked all the connections, I hooked everything back up. Anyone else ever have this problem?
That is weird - you could put any pulley you want on there, and it won't affect idle. Did you get the plug that goes on the bottom of the s/c? I think it's either for the tb or the bypass...but that would likely cause some issues if you didn't plug it back in.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
