Running rich!
Old Mar 3, 2013 | 12:44 PM
Vander Nars's Avatar
Originally Posted by 100% METH
Autolite 3923 1 step colder copper plug
$8 a pack
u sure about autolite? heard they suck to stick with ngk, but im about to go to the store to grab new plugs what gap?. Do u have any idea what could be causing me to peg rich?
Vander if you throw a code eventually, post up. I could print up the trouble shooting procedure from alldata.
ill post any codes I get sir.
Last edited by Vander Nars; Mar 3, 2013 at 12:44 PM. Reason: Automerged Doublepost
Old Mar 3, 2013 | 12:49 PM
100% METH's Avatar
I've never had a problem running a simple copper plug.
For $8, why listen to stories and try them for yourself.
.035 is a good starting point for your mods.
Your plugs looking the way they do atm is a good indication as why you are running so rich.
It's like I mentioned in a previous post. Check the coil packs if new plugs do not solve it.
It's intermittent, and only happening after repeated pulls.
Old Mar 3, 2013 | 12:50 PM
Lol ill try then i just hate to add to my problems was all i meant.
Old Mar 3, 2013 | 01:00 PM
nhanson's Avatar
I can tell my plugs are ready to be changed. They like to misfire in high RPM
Ive ran rich a lot this winter because of the MAF getting wet.
Old Mar 3, 2013 | 01:05 PM
I thibk 3923 is stock heat range and 3922 is one step colder what ones do i need lol
Old Mar 3, 2013 | 01:09 PM
100% METH's Avatar
Stock heat range is fine, I've ran that plug on all the Tvs, lysholm, mp90, m62 setups ice done.
Old Mar 3, 2013 | 01:35 PM
Tjolley's Avatar
Narrowband has nothing to do with wot afr. Wot engages open loop fueling
Unless op, just to clarify... Are you saying your cruising or idling and go from around 14.7 too 10.00, and back to 14.7
Or your going wot, hitting 11.00 then after a couple pulls pegging 10.00 afr during wot?
I was meaning to see if his wideband was going wacko. Mine did just recently
Old Mar 3, 2013 | 01:38 PM
mrbelvedere's Avatar
standard copper is best stay away from platinum the stock number for the 1 step colder is 4644 ngk
Old Mar 3, 2013 | 01:41 PM
383_Stroker's Avatar
LTFTs disabled? Is it holding a trim when you got WOT (possibly gradually increasing as you drive around ? lol)
Cat over temp disabled?
Old Mar 3, 2013 | 02:47 PM
OK update, I changed in plugs autolite 3322 gapped at .034, I just did a bunch of pulls(5 or 6) and even race and beat a modded mustang gt 4.6L(he looked shocked bahaha) and never went full rich, stayed around 10.9 to 11.0. However I had my interceptor up and watching the misfire option that list 8 cylinders and it was showing a lil miss fire(1 to 2) in all of them(all 8 not just 4) during normal driving(cruising) so im not sure whats up with that. Cylinder 8 was even showing 16 misfire randomly so any advice would be great 100% meth! but its seems u have fined my rich issue atleast, im data log in the morning and ill let you know if it is still holding up strong.
Old Mar 3, 2013 | 02:49 PM
  #36
ltft is not disabled, not sure what disabling them does if u would like to explain. I didnt watch the fuel trims during the pulls but I can do that later what one do I need to watch?
Old Mar 3, 2013 | 03:12 PM
  #37
Cot is what your lookig for, its abbreviated in hpt under fueling section tab.
10.00 can cause a mess of problems, misfiring in those cylinder are one of them.
COT says 0.00 for min and max
Old Mar 4, 2013 | 12:40 AM
  #38
Well iv been reading and it sounds like i have ghost misfire, i dont have any cels and their is no loss of power or hesitation or any kinda pop sound from the exhaust and its only happen during just normal driving. Anyone can confirm this is normal?
Old Mar 4, 2013 | 12:47 AM
  #39
100% METH's Avatar
Check for any vacuum leaks just in case
If a line needs to be replaced do it
Have james tune you're trims
Old Mar 4, 2013 | 10:14 AM
  #40
no its not normal
Old Mar 4, 2013 | 11:32 AM
  #41
Originally Posted by mrbelvedere
no its not normal
Iv read that this happens to most cars, I even had my friend check his interceptor gauge and hes does the same thing, it seems to be common thing I mean I dont have 8 cylinders so how can I have misfire on them. LOL
Anyone that has a cobalt and a interceptor go to the misfire screen where it shows the 8 cylinders and just cruse around for a lil bit and see if u get random misfire on all 8 of them.
Old Mar 4, 2013 | 11:39 AM
  #42
mine dosent show 8cyl
Old Mar 4, 2013 | 11:40 AM
  #43
mine has the chevy or saturn symbol u can pick from that will come up when turned on so I know its the one made for the cobalt and it shows 8cyl unless they is an option I missed to change it to show 4.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
