S/C bolts...need ideas.
trying to take the blower off and one of the allen bolts rounded out on the inside...any ideas to getting it off?tried hammering a slightly larger allen key in...didn't work...no room for vice grips...im at a loss other than drilling it out
**** happens sounds like its time for an easy out and for you to learn where to post my car is broke and that would be in the problems and service section not in the performance section
can you get a die grinder in there, if so try cutting a slot into the head of the bolt like we did on jerrys s/c pulley, then get a flat head screwdriver an hopefully it breaks loose
got it out.hammered a even larger allen in then put vice grips on the outside of it with all the strength I could put it to it and she broke loose...heads off already.
thanks guys!!
thanks guys!!
