Saab Exhaust manifold
now you can
here is what i said and what he said
ME:
if it is this engine
LK9 2.0T Ecotec
i need the Intake Manifold and Exhaust Manifold
HIM:
I believe the parts you need, and im only saying this because you capitalized the "T", are ones off of a 9-3 SS with an engine code of B207R. The engine on this car is the B207L.
Your going to need to confirm it thou...but i do have both mani's on this engine.
ME:
LK9 2.0T Ecotec
HIM:
i updated my post, also remember some of the saabs came with SAI, some didnt
they are getting ~200whp, 270wtrq outta 6psi over on the jbodies, but they are 2.2's, not 2.0's...
would i be able to get 350whp out of it on my car?
and can i use the oil lines from it?
Last edited by venum_us_2002; Aug 12, 2009 at 03:59 PM. Reason: Automerged Doublepost
u can use the oil lines from it fine, i dont think u couldget 350hp out of it, its a small turbo, i have pics, sec
take the turbo, the manifold, the oil lines, the cold charge pipe...u may be able to, but its a small turbo, ud be pushing well over 20psi...but who knows, i havent checked the saab forums in a while, u could try posting over on saabcentral and just ask if you can get 350hp out of your saab 9-3 b207r engine using stock turbo...see what they say
350whp ain't gonna happen with the stock saab turbo. I believe it uses a garrett flange, no reason you can't get a bigger turbo.
I stand corrected. That 3 bolt flange looks pretty wierd.
just bolt it on your ss/sc and twincharge it. That should net you 350whp.
Last edited by ralliartist; Aug 12, 2009 at 04:06 PM. Reason: Automerged Doublepost
the b207l used a garret low pressure turbo, the b207r used a MHI(mitsubishi heavy industries) high pressure turbo, althought they are both the same as far as bolt patterns, and fitment...
Why not just buy the Vulcan log manifold or the ZZP one? Then you can have any freaking turbo your heart desires. I can see modding the intake manifold off the Saab, but not using that crappy turbo manifold. I think you need to set down and do some serious research before diving into this as it will save you time and money in the end.
if you want to use a cheap factory turbo, ebay the evoiX turbo, there are a few cheap ones, than have vulcan make u a log mani w/that flange...i believe they are twinscroll turbos too...even a big16g turbo will get you the 350hp u want and have minimal turbo lag...and luckily the o2 hosuing is cheap on ebay aswell to that helped u make the downpipe alot easier, as u can use the turbo and o2 hosuing together...trust me, making a DP for a turbo that is internally gater is a lot easier when u can use the factory or aftermarket o2 hosuing :p
