SC Silencer holes
Old Nov 6, 2008 | 02:47 PM
  #51
MBMCustoms's Avatar
Originally Posted by rockSTAR_SS
Compared to an autometer mechanical boost gauge...yes.
They work just fine if you don't see the need for an aftermarket boost gauge.
so what really would the difference be? i dont see the point to an after market gauge unless our gauges are off by a **** load.
Old Nov 6, 2008 | 02:55 PM
  #52
Hockeyman's Avatar
since our gauges read from the PCM and are not connected to the actual vacuum lines, they tend to be slow or off a bit.
Old Nov 6, 2008 | 02:59 PM
  #53
MBMCustoms's Avatar
as long as its not off by a lot then im fine. if it is off by a lot then i might consider a new gauge. but if its just a little slow then i really dont care.
Old Nov 6, 2008 | 04:14 PM
  #54
rockSTAR_SS's Avatar
I never said the stock gauge was INACCURATE. You're not getting my point.
Old Nov 6, 2008 | 06:28 PM
  #55
SSdan's Avatar
It actually is btw.
Old Nov 6, 2008 | 06:35 PM
  #56
USMCFieldMP's Avatar
Rattlesnake Race Shop
Stock boost gauges are SLOW AS ****...
Old Nov 6, 2008 | 06:45 PM
  #57
HunterKiller89's Avatar
mechanical FTW instant readings
Old Nov 6, 2008 | 08:32 PM
  #58
Originally Posted by SSdan
It actually is btw.
Yeah I knew it had to be.
I paid $70 for my autometer ultralite II mech boost gauge. Well worth the money, it looks better than stock IMO (goes better with my yellow gauge face), and is dead accurate with instant vaccuum/boost readings.
Old Nov 7, 2008 | 07:27 PM
  #59
MBMCustoms's Avatar
thanks for the info guys. i may end up getting a new gauge now. slow is not what i want to be.
Old Nov 15, 2008 | 12:47 AM
  #60
Hodz's Avatar
Id like to do this too just for the simple fact i would like the super to be louder... but the gains dont seem to out way the fact that if you dont do it right you could mess up the supercharger or the engine....
Old Nov 15, 2008 | 12:56 AM
  #61
You aren't going to screw anything up if you follow these simple steps:
1.) Buy QUICKSTEEL... not JB Weld!
2.)Sand down the grit on the silencer holes before applying Quicksteel.
3.) Don't let the Quicksteel stick through the holes and into the S/C Rotor area.
If you follow those simple steps... you'll be fine.
Old Nov 15, 2008 | 09:00 PM
  #62
MBMCustoms's Avatar
thank god thats what i did
Old Nov 16, 2008 | 03:44 AM
  #63
why would you want to sand down the grit? wouldnt the grit give the quiksteel more surface area to adhere to? If anything, i would have guessed you'd want to skore (sp?) it up and make it rough
Old Nov 16, 2008 | 10:16 AM
  #64
flash13brandon's Avatar
Thats what sanding it down does. Makes the quicksteel adhere better...
Old Nov 16, 2008 | 03:17 PM
  #65
What this guy said:
You sand it down with a rough sandpaper (80 grit or so).
Old Nov 16, 2008 | 03:26 PM
  #66
Mnatvyc1223's Avatar
jesus this topic has been beat to death numerous times!
Old Nov 16, 2008 | 11:45 PM
  #67
MBMCustoms's Avatar
it has but i guess everyone will learn one way or another. i went through five threads of this stuff before i was really sure of what to do.
Old Nov 17, 2008 | 10:02 AM
  #68
That's how you learn before going out and just trying something and screwing something up...if its a common mod that people will debate than who cares if there are numerous threads about it...Good job Customs, I'm glad you did it right
Old Nov 17, 2008 | 11:48 PM
  #69
mdodge05's Avatar
will welding it hurt the superchager or not
Old Nov 18, 2008 | 12:10 AM
  #70
EmperorJJ1's Avatar
supposedly yes
Old Nov 18, 2008 | 12:15 AM
  #71
mdodge05's Avatar
how wo\uld it it u get it done right
Old Nov 18, 2008 | 05:41 PM
  #72
mdodge05's Avatar
how would it if u get it done right
Old Nov 18, 2008 | 05:50 PM
  #73
Because welding will cause EXTREME heat to a FINISHED product. I don't know the technicals. TVS_SS explained it once.
Basically... it'll warp your S/C Housing.
Old Nov 18, 2008 | 05:59 PM
  #74
invisible's Avatar
Unless you no what your doing.
A really good welder could do it but make sure they no there ****.
Old Nov 19, 2008 | 12:02 AM
  #75
MBMCustoms's Avatar
i still dont think i would try it
