seeing 10.5 afr at wot?
Old Feb 25, 2008 | 08:47 AM
07cobaltss's Avatar
at wot i'm seeing 10.5 afr then it starts to taper up to 12.5-13 anyone else seeing this with the 2.9?
Old Feb 25, 2008 | 08:49 AM
BOOSSTED 06's Avatar
yeah thats pretty damn rich for wot on any pulley especiallly if you have the stage 2 tune still on there and went to a smaller pulley
Old Feb 25, 2008 | 08:53 AM
Darkmanx's Avatar
I see 11's then it goes to 10.5 in third. with stage tune it was all 10's
Old Feb 25, 2008 | 08:54 AM
Rodimus_Prime's Avatar
well 12.5 to 13 certainly isnt good
Old Feb 25, 2008 | 08:56 AM
yeah thats not good at all either
Old Feb 25, 2008 | 09:10 AM
SJSchafer's Avatar
Your COT is kicking in at WOT or your trims are too high just before. With stage 2 you should start out in WOT in the 12s and taper down to 10.8. You're seeing the high numbers towards redline because your injectors are going static.
Old Feb 25, 2008 | 09:13 AM
07cobaltss's Avatar
well the at idle i'm seeing 14.5-15.5 fluctuation. but yeah i do see 10's till around red line then i see around 12.5
static with a 2.9 pulley?
Last edited by 07cobaltss; Feb 25, 2008 at 09:13 AM. Reason: Automerged Doublepost
your idle is right normal it will bounce in that range normally staying around 14.7, or stoich
yeah definitely have someone turn of you Cat over temp
Last edited by BOOSSTED 06; Feb 25, 2008 at 09:13 AM. Reason: Automerged Doublepost
Old Feb 25, 2008 | 10:54 PM
SJSchafer's Avatar
I have seen people static with a stage 2 pulley. You're pushing in more air than your injectors can supply fuel for. With a 2.9, a tune can help some. Going that lean at the top is definately static injectors.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
007Buff
Jun 11, 2017 03:04 PM
007Buff
Sep 22, 2015 09:48 AM
TylerJHowell
Sep 21, 2015 06:47 PM
