which set up?
Old Sep 29, 2009 | 03:48 PM
06cobalt_ss's Avatar
which set up?
Which exhaust is a better setup with the most gains?
My mods are:
Cai
2.79 pulley
60s
Ottp rotated mounts
Traction rods
Cx h/e
1step colder plugs
Devils progressive meth kit
Gmpp upgraded clutch
24 deg timming
My question is which exhaust set up is better for my mods. I don't plan on doing any other mods except suspension and an exhaust.
Choice A
Zzp mid length header 1.75 primaries 3in outlet, zzp 3in in and out catless dp, zzp 3in cat back no res.
Choice B
Zzp midlength header 1.75 primaries 3in outlet, zzp 3in in and 2.5in outlet catless dp, any random 2.5 in cat back
Thanks guys
Old Sep 29, 2009 | 04:04 PM
ShortStack's Avatar
My thoughts ..
If your planning on staying with the 2.8" pulley.. then you could consider the 2.5" catback and it may actually help your tq a little..
If your going to ever upgrade though, you are right on the verge of needing the 3" exhaust...
Old Sep 29, 2009 | 04:08 PM
Originally Posted by ShortStack
My thoughts ..
That's what I'm courious about being that I'm right on the boarder between 2.5in and 3in should I go to 3in and maybe lose 2much back pressure or shud I got 2.5 and maybe have 2 much back pressure?
Old Sep 29, 2009 | 04:11 PM
EXsoccer1921's Avatar
hahn.
JapEatr's Avatar
South Central *********
HAHN 3.0", call it done! Youll thank me later
Old Sep 29, 2009 | 04:13 PM
jap, i think every exhaust thread there is. me and you are in there reppin' hahn. hahaha
Old Sep 29, 2009 | 04:15 PM
ShortStack's Avatar
We dont want any backpressure... we want exhaust velocity...
Really, as long as you have a 3" dp... your better off...
You will have better velocity with the 2.5" up to a certain point, then it will become a restriction..
your kinda on that border right now...
If you feel you may pulley down sooner or later... or go with another type of forced induction, than go with the 3".
Old Sep 29, 2009 | 04:17 PM
TurboTechRacing's Avatar
hahn.
Good thoughts
JapEatr's Avatar
I went through a ton of money and like 5 different exhausts before i found one i even could tolerate. I may even put the cat on to make the Hahn sound that much smoother...but i doubt it.
Old Sep 29, 2009 | 04:18 PM
he's already(technically below) at a 2.8, i'm running a 3" on that same setup. just different plugs and a stronger methanol mix with 25*. a 3" will work just fine.
Originally Posted by TurboTechRacing
Good thoughts
great sound
Last edited by EXsoccer1921; Sep 29, 2009 at 04:18 PM. Reason: Automerged Doublepost
Old Sep 29, 2009 | 04:45 PM
Does that hahn catback bolt together or does it have to be welded (meanin when it is delivered and broken up in diffrent swections do the bolt together to make the cat back or are they welded)? Does it bolt up to a 3in zzp down pipe?
ShortStack's Avatar
the hahn has some nice clamps that make it fit together..
And yes, yes it does...
Old Sep 29, 2009 | 04:52 PM
So what your sayin is if I get the 3in hahn catback it is all bolt on not one bit of welding and it is a direct bolt on to my zzp in dp? Did I get that rite?
Old Sep 29, 2009 | 04:59 PM
the hahn system uses clamps to make adjustments in length so it fits right. but it bolts to the downpipe like a normal exhaust, and then it....i'll get some pictures...
Old Sep 29, 2009 | 05:06 PM
rnjmur's Avatar
If you aren't going to do anything else to it for sure, I would stick with the 2.5", better to keep a little more HP and TQ in your midrange.
If you think you may at any point possibly go NO2 or go with a 2.7 pulley or turbo, then I would definately go 3" or you will be changing the exhaust out again.
Old Sep 29, 2009 | 05:08 PM
Direct bolt on.
As most will state, it is better to stick with one brand, than to mix and match, as that is when issues may arise.
Old Sep 29, 2009 | 05:20 PM
this.
alright here's some pictures.
obviously the header and downpipe aren't going to move. on the catback itself, the flange that bolts on to the catback is actually only about 7-8" long. and then that clamp/bolts on to the main body of the catback, that is used for front-back length adjustment. then at the 90* bend, theres another clamp, and thats used for side to side adjustments and final position of the muffler.
Old Sep 29, 2009 | 05:21 PM
^^^ Very nice setup!
Old Sep 29, 2009 | 05:25 PM
sounds nice too. i don't know if the link will work for you guys though.
http://www.facebook.com/home.php#/vi...=1227363877450
Old Sep 29, 2009 | 06:13 PM
Omnigear's Avatar
vbg is where my mods at
i have no problem with my
ark 2.5
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Sep 27, 2015 08:53 PM
