Shakey SS
Old Aug 7, 2005 | 01:53 PM
PaulSS's Avatar
Shakey SS
whenever im doin about 60 and i hit the brakes.. i feel a slight vibration in the steering wheel.. if i let go of the whell.. it shakes back and forth almost violently.. i just hit 5k and i really cant see my brakes already beeing bad.. also this has been happening since about 2k.. anyone else have the same issue?
Old Aug 7, 2005 | 02:43 PM
redrocket's Avatar
Sounds like the disks are warped. Most likely they were overheated or the wheels are torqued improperly. Just a thought.
Old Aug 7, 2005 | 02:55 PM
MarcS's Avatar
The Stig
Take it in, probably warped rotors due to overtorque.
Old Aug 7, 2005 | 03:44 PM
JapEatr's Avatar
South Central *********
more like undertorque
mine were loose when i bought mine ~40 ft.lbs
should be 100 ft/lbs
Old Aug 7, 2005 | 03:53 PM
MarcS's Avatar
The Stig
That's pretty damn low. You should have complained, that's just unsafe.
Old Aug 7, 2005 | 08:34 PM
DARK AGE 53's Avatar
As others have said it's probably warped rotors, when torquing your lug nuts use the star pattern...and if you really want to do it right first torque the lug nuts to 50 ft/lbs, 75 ft/lbs and then finally 100 ft/lbs.
Old Aug 7, 2005 | 09:08 PM
selfinfliction's Avatar
yeah when i went to pull out my airbox my lugs came off easy so i put a torque wrench to the rest and they were all between 35-30 ft pounds... i would recommend that EVERYONE check those lugs immediately after purchasing the cars.
G5_Stuntin
Oct 22, 2012 09:37 PM
Fastgti69
Oct 20, 2012 01:31 PM
dalex44
Aug 22, 2012 04:50 PM
Godly
May 14, 2012 10:40 AM
Preston
Nov 15, 2007 07:03 PM
