Should i get Extruded Honed Performance Exhaust Manifold
should i get GMPP Extruded Honed Performance Exhaust Manifold while i am having my stage 1&2 and K&N Typhoon installed at the dealership ! its an extra $400 but need to know if it is going to give me any noticable performance diff. or if it's not really neccessary ? please help me decide!
Originally Posted by pvirga88
I would go with a Header Downpipe. You should check out Cobalt Addiction they have a nice setup.
I have 0 complaints.
If your intent is to be as fast as possible with GM parts the extrude-honed manifold reportedly gives you 7% more flow. That's exhaust flow increase -- not horsepower increase.
Since you went with the K&N intake it looks like you're not staying stock-only. In this case a header will certainly provide more HP increase/potential over a manifold. If you're lucky enough to have a dealer that would put this on and not argue over your warranty go for the CA header.
Originally Posted by Red2.4SS/SC
i would go with zzp there header has a 2.89 in collector i think the cobalt addiction ones only have a 2.25 collector on the ones that are 199.99 at least, but whatever floats your boat
Thanks guys
Originally Posted by NKs07CobaltSS
So basicly everyone is telling me is to get something other than GMPP the only reason i want to know is because the dealership is putting stage 1&2 & CAI on Thursday and if they were going to have it tore apart it might have been a good time to invest in that as well! but if everyone is saying get another kind then i might just hold off for a while and get it from somewhere else.
Thanks guys
Thanks guysIf you want the most gains, go with aftermarket.
thanks guys i think i'm gonna pass on the Extruded Honed Performance Exhaust Manifold and wait to get a CA header which is not covered under my warrenty down the road!
Remember, the only way they can't cover something under warranty is if the aftermarket part directly caused the problem.
In other words if your sunroof stops working they can't say your warranty is gone because of a header.
It would have to be the header's fault.
I got mine installed when I purchased the vehicle. I never really noticed anything.
Do you have the GMPP cat-back performance exhaust? If not, get it and a GMPP exhaust tip (angled or straight - your choice).
CA header fits in place of manifold -- no alterations needed. GMPP performance exhaust replaces original exhaust perfectly -- just have to cut out the original system to install it. CA has downpipes to replace your original downpipe too -- go to their website for info.
ok i'm not a performance savy person so is the header attatched directly to the Cat back or is there anything in between i've heard down pipe and not quite sure i know what that references to?
Originally Posted by distillion
you didnt feel anything cuz you purchased your car with it installed, you had nothing to compare with, i installed it a few months after i installed the gmpp sport exhaust and i felt a nice difference, to each there own.
done together wherever possible.I'm Just not a mechanically inclined person!
Thanks distillion Thats what i wanted to know in the beginning. just don't want to buy something then turn around and have buy something better. I'm in no real hurry with getting anything but all my work will be done by shops so its more efficient to get things
Originally Posted by Matty
A flexpipe,downpipe, and catalytic convertor is between the header and catback.
do i need to uprade those peices as well! and can i get them from CA as well if so!
The choice is yours to upgrade. The aftermarket piece does smooth out a section where the stock one narrows.
Those 3 pieces are actually all conected when you get a downpipe (one with a cat)
