Simple Question
Old Feb 15, 2008 | 07:04 AM
SnappyChevy's Avatar
Simple Question
On a Gm stage 2 is it common to get boost bleed. I just noticed the other day that i hit 15psi like i should, but once i start getting close to redline 5500 or so i start to bleed down to 10psi or so. The bad thing is i cant remember noticing this before. I just would like to know if this is common\correct\normal or should i have the dealer look at the car.
Old Feb 15, 2008 | 07:25 AM
Super_SS's Avatar
not on a supercharger...our pulleys control how much boost u get...u should be hitting 15 and slowely gaining more boost towards redline..max around 16.5-17psi
Old Feb 15, 2008 | 07:36 AM
rockkrawler628's Avatar
yea but doesn't the bypass mod prevent the system from bleeding off boost??? i kno the car runs 12.5 stock but when you get a pulley and so it'll get more and get boost quickly so just doing the GM Stage 2 means it'll hold 15 or so psi all the way to redline???
Old Feb 15, 2008 | 07:47 AM
Super_SS's Avatar
it will hold 15psi minimum,but should reach peak boost by redline...which is around 16psi or so
Old Feb 15, 2008 | 08:36 AM
rms7design's Avatar
I have 15psi max with stg2. In an other thread that I initiated, you can get more psi but need smaller pulley than the one coming with stg2. as for bleeding, I guess it also depends on the external temperature... but rarely do I go above 15psi if almost never..
Old Feb 15, 2008 | 08:41 AM
06black's Avatar
check for belt slip.
if your "peaking" then dropping boost as the rev's climb, as the loads on the blower increase(thus forces against the belt) its a common sign of the belt slipping. you might not even hear anything while its happening.
snag a new belt for a few $$$ and slap that on, i bet your issues will go away.
Old Feb 15, 2008 | 09:28 AM
invisible's Avatar
yep, belt slip is most likely your problem
Old Feb 15, 2008 | 11:21 AM
rnjmur's Avatar
It is probably belt slip, but it could be knock or abuse settings as well. I know the Stage 2 does not bleed boost unless your IAT is too high, abuse is detected (transmission or engine) or engine coolant temps are too high.
Old Feb 15, 2008 | 01:23 PM
How would another stage 2 belt help me if this belt is slipping. Plus this will do it all the time i can start the car up and it will bleed off boost or i can do it after ive been driving for awhile and it will still do it. so i dont think the abuse thing is the answer. is there any chance my cold air could be clogged with snow or ice or something since we did just get alot of snow and crap this week and i had to drive in it
Old Feb 15, 2008 | 02:11 PM
rnjmur's Avatar
The belt may have been damaged or gotten crap on it when the stage 2 was installed. If so, replacing it will fix the problem. Maybe, they didn't even put the stage 2 belt on so you are still on the stock belt - where did you have the stage 2 installed or did you do it yourself? If you had a dealership do it did you get back the old parts? I made sure to tell them I wanted all the old parts back so I could be sure they did everything they were supposed to.
If it isn't the belt then it is more then likely the PCM pulling the boost for some reason. It could be that the cold air is clogged - but it could be excessive knock or one of the injectors is going static. It could be your spark plugs as well. You are going to have to just start checking your air filter and plugs and go from there.
Old Feb 15, 2008 | 03:47 PM
06black's Avatar
ugh...ok.
look, eaither get another stg2 belt(not the best idea) OR be smart, get a STOCK belt and a 76mm idler pulley.
put pulley on, then apply stock belt, thus giveing you a greater then stock tension. for example.
a 2.7 Billet flow pulley with a 76mm idler and a stock belt retains stock belt tension, so if your at a 2.8/2.9 your going to have a bit more tension on there so you'll at least be able to rule out this if it doesn't fix the issue.
we had vary similar symptoms on a local car and this was the fix.
Old Feb 15, 2008 | 07:17 PM
thatotherguy's Avatar
You got a leak somewhere in your lines. i had the same problem.. i top out at 18 when i had my old pulley on and around 6000 rpms i would go down to 9 or 10 psi
Old Feb 15, 2008 | 07:19 PM
hungryhip-ccp's Avatar
thats not normal
Old Feb 15, 2008 | 07:22 PM
Originally Posted by hungryhip-ccp
thats not normal
no really.. thats why i fixed it.. .
Old Feb 15, 2008 | 07:50 PM
frdmustang92's Avatar
on stage 2 with 2.8 i get 18 psi
Old Feb 15, 2008 | 08:26 PM
Super_SS's Avatar
i get 20+
Old Feb 15, 2008 | 08:36 PM
oh yeah... well i get 12.5...... STOCK!
Old Feb 15, 2008 | 08:44 PM
ptrblkz24's Avatar
Are you sure you got the stage 2 reflash?I thought i remember reading that the stock program bleeds off boost if you put a smaller pulley on the car.I could be wrong though.
Old Feb 15, 2008 | 09:33 PM
rnjmur's Avatar
This is a good point... I didn't think to ask... can you actually hit the 7000 redline?
Old Feb 16, 2008 | 08:57 AM
yeah they told me they reflashed it put it that way. I keep getting a rich CEL. Is there anychance it could have something to do with the MAF i was driving in some snow and ice the other day and it was pretty deep. Could I have crudded up my MAF or clogged up my air filter.
Old Feb 16, 2008 | 09:58 AM
mrniceguy8211's Avatar
Cai + Rick code = bad Maf, happend to me. Get it replaced asap, and my stage 2 with the 2.9" pulley peaks at about 19.5 psi.
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
