single pass!
Old Mar 3, 2010 | 10:44 PM
advise's Avatar
single pass!
http://www.zzperformance.com/cobalt_...s1.php?id=1163
discuss
Old Mar 3, 2010 | 10:52 PM
irishredheadpa's Avatar
sooooooo? arnt the 2tock intercooler systems single pass already
Old Mar 3, 2010 | 10:53 PM
s1lver's Avatar
Originally Posted by irishredheadpa
sooooooo? arent the stock intercooler systems single pass already
stock is 4 pass.
Old Mar 4, 2010 | 07:37 AM
Staged07SS's Avatar
Administrator
Administrator
subd
Old Mar 4, 2010 | 08:10 AM
ralliartist's Avatar
Stock = 4 passes through the manifold, coolant enters in one nipple on the stock endplate, makes 4 passes back and forth through the manifold, then exits through the 2nd nipple on the stock endplate.
Dual Pass = Only 2 passes through the manifold, coolant enters through both the stock nipples on the stock enplate, makes only 2 passes through the manifold, then exits through a 3rd niple drilled into the center of the stock endplate.
Single Pass = 1 pass through the manifold, coolant enters through an aftermarket enplate on the passenger side of the manifold, makes 1 pass through the manifold, and exits through the stock enplate nipples on the driver's side.
FYI, $400 dollars is a very good price for a single pass manifold.
Last edited by ralliartist; Mar 4, 2010 at 08:10 AM. Reason: Automerged Doublepost
Old Mar 4, 2010 | 11:19 AM
Xephirothx's Avatar
Price is good... Waiting on pic's and how-to as well as if their is a core charge discount for sending in our manifolds..
Old Mar 4, 2010 | 11:32 AM
recklessactn's Avatar
hmmm wonder what kind of flow rates they saw (increase/same/decrease) and overall performance gained. If significant enough this could allow us to push the tvs/m62 harder and without temp issues
Old Mar 4, 2010 | 11:47 AM
Fonzi1289's Avatar
SUBd not a bad price!
ANd yeah same bout the core charge!
Old Mar 4, 2010 | 11:50 AM
PerformanceClutches's Avatar
i am still wondering if for the time and money if the dual pass end plate + option b is worth it. i can get the end plate for $120 shipped and the option b for like $120. so that's $250 in the hole + half a day or more installing it. Gains?!?! worth it or no?
Old Mar 4, 2010 | 12:14 PM
i have my option b plus dual pass endplate plus smg fmhe still sitting in front of my tv here, but i would like to see what zzp has to say about this product ( not bashing for anyone keeping tabs )
Old Mar 4, 2010 | 12:24 PM
Stiner's Avatar
This is the best cooling with the stock Intake manifold for a decent price if I was supercharged I'd hop all over this.
Old Mar 4, 2010 | 12:32 PM
stenguyen1's Avatar
I would like to see some pics also
Old Mar 4, 2010 | 12:37 PM
-Jayson-'s Avatar
might be worth it if you had a pump that could keep up with the required flow rate, i doubt the stock one could keep the pressure up high enough to keep the top cores filled with coolant.
I am really interested to see how they did this as it should require a new/modified intake manifold.
Old Mar 4, 2010 | 12:51 PM
The stock pump is perfectly fine as far as flow rate. I actually had to reduce the flow since the single pass gets rid of restriction and I needed to slow the coolant down a tad to help the exchange of heat in the manifold.
Some of you guys just spout **** out that gets others worried for no reason. It'd be better to do some research before talking. I haven't seen anything new pop up in a long time that hasn't already been answered on this forum.
Don't take that the wrong way.
Old Mar 4, 2010 | 05:37 PM
el_roy1985's Avatar
I was actually just trying to figure out how to do this last month. I deemed that it was possible, so I'm interested to see how similar this will be to what I thought up.
Old Mar 9, 2010 | 09:49 AM
Xephirothx's Avatar
bump For more info
Old Mar 9, 2010 | 10:02 AM
Unforgiv3n's Avatar
Sub'd
Old Mar 9, 2010 | 02:46 PM
YzRider452's Avatar
Im making a single pass right now. Its not really much more work than making a dual pass.
Old Mar 9, 2010 | 02:53 PM
Staged07SS's Avatar
Administrator
Administrator
post your results when you are finished man !!
Old Mar 9, 2010 | 10:19 PM
SS Pyro IV's Avatar
can we get a diagram on howd this would be run? maybe some pics.....
Old Mar 9, 2010 | 10:27 PM
shadowfaxss's Avatar
I just installed the dual pass, option B and front mount H/E. Definately worth the money IMO. Other things to cool the intake charge but this doesn't require any tuning. IAT temps recover quickly.
Old Mar 10, 2010 | 05:24 AM
YzRider452's Avatar
Im going to post before and after IAT2 on a dyno run. Im sure the results with be very pleasing. Im already planning on making atleast 3. One for me, and one for 2 of my buddies.
Old Mar 10, 2010 | 05:33 AM
rallyracer's Avatar
sub.
Old Mar 10, 2010 | 06:21 AM
WickedSS2005's Avatar
I want pics and info from the seller
Old Mar 30, 2010 | 02:53 PM
Any updates on this, I want to order for a dual passset up or possibly single pass
