Size of SS exhaust???
Old Dec 16, 2005 | 09:28 AM
Hot Carls R/T's Avatar
I got a 2005 Cobalt SS/SC and was wondering how big the factory exhaust is 2.25" or 2.5" and does it go into 2.25" at the muffler? I have a magnaflow muffler and was wondering if I would get much power increase changing the factory resonator? I just don't want too spend 500-800 dollars on a cat-back exhaust.....Thanx
Old Dec 16, 2005 | 10:56 AM
Jmc007's Avatar
Stock is a 2,5" catback, but the rear section (rear axle to muffler) is 2,25" crushed bend. Replace it to 2,5" along with a straight through Magnaflow. 10 WHP gain.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/how-custom-magnaflow-vibrant-2-5-ss-catback-intake-mod-parts-needed-5478/
A catback (or a custom one) is a MUST before making any other mods on the SS.
selfinfliction's Avatar
my personal opinion is you won't see any gains from changing the factory resonator... it doesn't even have inward facing baffles... your biggest choke points are the muffler and the manifold
Old Dec 16, 2005 | 10:57 AM
i don't think everyone has crushed bends.. when i cut off my stock setup, it was mandrel
Old Dec 16, 2005 | 07:35 PM
Thanx alot for you help guys....I already have a Magnaflow Universal muffler on my car with a 2.5" inlet/4" outlet. I was really inpressed with the gains just with changeing my muffler as the stocker is heavy and decreases hp the most. I just wanted too see if it was worth it to change the factory resonator....I just don't see spending 500-800 dollars on a catback the same diameter as the stock system...Its money I can use for the GM Stage 2!
Old Dec 16, 2005 | 07:40 PM
05vicredSS's Avatar
same thing I plan to do
Old Dec 17, 2005 | 10:49 AM
Its a great mod man...I spent 200CAN on the stainless magnaflow race series muffler and 50bucks too install it! Awesome cheap mod too make good hp gains....
Old Dec 18, 2005 | 03:27 PM
codyss's Avatar
I wonder if you can order replacement parts for any of the cat-back kits yet?
If you can a guy could just order the section of pipe that goes over the axle to the muffler. It would be stainless and have all of the correct bends and hangers.
I know that Dynomax has a part number for each piece.
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
