wheres our throttle under the hood?
Old Dec 18, 2005 | 11:55 AM
JCswoosher2's Avatar
i have been looking for the throttle under the hood. and i cant find it. im wanting to rev the engine while being under the hood. a picture would be great. thanks
Old Dec 18, 2005 | 11:59 AM
eastcoastz's Avatar
Cableless throttle.
Old Dec 18, 2005 | 12:00 PM
ummm so wheres it at?
avro206's Avatar
well its electronic--so we might not have one in the tradtional sense
Old Dec 18, 2005 | 12:01 PM
wesmanw02's Avatar
Originally Posted by eastcoastz
Cableless throttle.
Exactly. Its a "Drive-by-Wire" system, therefore there is no actual throttle "cable" to speak of. Its all electronically controlled.
So basically you can't rev the engine from under the hood like on the older cars, you actually have to go inside and press the gas pedal
Old Dec 18, 2005 | 12:29 PM
eastcoastz's Avatar
Ummm where your factory induction connects to your blower.
Old Dec 18, 2005 | 12:46 PM
Dman's Avatar
wow, um yeah, its where the intake tube connects to the blower.................
Old Dec 18, 2005 | 01:00 PM
SilverSS/SC's Avatar
It could probably be electrically manipulated , then again Im sure the resistence value used are probably gonna be tough to manipulate . This is a bit excessive , haha , but you could get a accelerator pedal out of wrecked Cobalt , make a extender harness . Unpug the pedal in the car , and plug in the extender harness , run it to the engine bay and plug in loose accelerator pedal
Since throttle blades (minimum air rate screw ) , IAC motors and TPS's are not manually adjustable anymore like they used to . I really no longer see a need to beable to give the engine throttle from the engine bay , unless you were just reving to show off .
Old Dec 18, 2005 | 02:04 PM
Jmc007's Avatar
Don't mess with that. The PCM will throw codes after codes after codes (CEL). I just purchased the service manual set, and all the TPS sensors are continuously verified by the PCM. Plus the fact that if there is something wrong with the throttle motor, the car will go in the reduced power mode.
Old Dec 18, 2005 | 02:48 PM
Malaclypse's Avatar
All Accelerator pedal wiring runs through the PCM. Don't fiddle with any of it.
And revving the engine while under the hood is useful for certain diagnostic tests. Alternator, belt noises, etc.
Old Dec 18, 2005 | 03:27 PM
AlphaJaguar5's Avatar
Rig up a pulley system to the gas pedal so you can rev it from the engine bay
Old Dec 18, 2005 | 03:53 PM
DanM's Avatar
Or just find a friend.
Old Dec 18, 2005 | 05:12 PM
Cirrus's Avatar
A what???
Signed,
JCswoosher2
DarrenGC
Dec 24, 2021 01:55 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
yellowsupercharged06
Sep 15, 2015 04:38 PM
