slvr 04 rl turbo build
Old Oct 17, 2010 | 08:34 PM
slvr 04 rl's Avatar
well the time has come and my car is about done. as of right now the car is at the shop having the intercooler piping made. ill post finished pictures when i get it back which should be this coming week.
this custom kit took alot of modifing just to get it to fit right. i bought the kit from USMCfield. here is what the kit consit of...
persicion 5031
vulcan tubular exhaust manifold
vulcan intake manifold(modified)
custom catless downpipe
HKS super sequenctial blow off valve
not sure of the wastegate. looks like a knock off
blox manual boost controller
cx racing intercooler
custom intercooler piping(getting done by CMS performance)
im sure in forgeting things but you get the jist of it.
anyways, here are some pictures.
freshly rebuilt turbo by thirdcoast turbos.
exhaust manifold
turbo bolted on
see how close it is to the speed sensor. also had to cut up my rear trans mount to get the downpipe in and modify the heat core hose so the wastegate could fit.
the vulcan intake manifold was garbage. but i got a good deal on it(i think lol) it didnt fit correctly, had to open the holes to bolt it to the head. the welds covered the holes to screw the throttle body in and i didnt like how they put all the fittings on top of the manifold so alot of modifing was done.
now you seem them...
....now you dont...
under the manifold.
thats a ZZP map pad. since the manifold doesnt house the sensors in them.
inside..
one thing that shouldnt have givin me a problem but did since the shop i had weld my fitting into the oil pan sucks. i had to pull it all back off again and redo it differntly.
crap welds and so the grinded them down and nicked the fitting so that was leaking, as well as there crappy weld was leaking.
so new oil drain set up.
baby intercooler.
i will post more pictures when i get it back.
Old Oct 17, 2010 | 08:46 PM
Pedobear's Avatar
awesome, and double awesome retros
Old Oct 17, 2010 | 08:49 PM
mexi_loco's Avatar
nice job miles! so is kendell tuning you as well? Also, what size injectors did you decide to go with? And did you ever decide to run a rsfs?
Old Oct 17, 2010 | 08:52 PM
slvr 04 rl's Avatar
thanks, and thanks.
im running 80s and i have a ott return style and walbro fuel pump. not sure if i want to put it in yet though.
Old Oct 17, 2010 | 08:54 PM
Perfect.disguise's Avatar
Looks good.
Old Oct 17, 2010 | 09:12 PM
Frew's Avatar
off topic but your retros are sex
Old Oct 17, 2010 | 09:20 PM
mexi_loco's Avatar
I've heard fuel cuts off around 350 hp on the stock fuel system, so at least the rsfs would help. It would also make tuning easier as well. It's up to you to put in the fuel pump, but I would just stash that in the closet for whenever the stock one goes. That's just my .02
Old Oct 17, 2010 | 09:47 PM
slvr 04 rl's Avatar
i am going to put it on. just not at the moment
Old Oct 18, 2010 | 06:37 AM
selfinfliction's Avatar
looks good man
Old Oct 18, 2010 | 06:40 AM
cmatthewb101's Avatar
Looks good man. Sub'd for official numbers
Old Oct 18, 2010 | 03:18 PM
jdunn622's Avatar
i have a boner
Old Oct 19, 2010 | 12:25 PM
slvr 04 rl's Avatar
i get the car back next week. then ill probably get it street tuned then soon after that ill have it dyno'd
Originally Posted by jdunn622
i have a boner
keep it in your pants
Old Oct 19, 2010 | 05:52 PM
07SS_chick's Avatar
cant wait till i see it on the street...keep it up looking good
Old Oct 23, 2010 | 08:19 PM
slvr 04 rl's Avatar
problem
alright, i got the car back yesterday and when i was driving it, it was smoking really bad. i found the oil feed line was leaking. i fixed that and it was still smoking, i figured it was the oil burning off. well its coming though the exhaust tip so im guessing the oil is getting back up into the turbo and coming through the exhaust. any one have an idea of fixing this? im thinking about mounting a scavenger pump to pull the oil through.
Old Oct 23, 2010 | 08:26 PM
LobstaBisque's Avatar
Perhaps a restrictor could be needed for the oil feed? Or a kink in the return line, or bad return line angle?
Old Oct 23, 2010 | 08:32 PM
slvr 04 rl's Avatar
its a journal bearing turbo so people said i didnt need one. its a 4an feed and a 10an drain. i couldnt get a picture of the feed, but its short and i dont think there is a kink in it. and did you see the pictures? there is no kink in the return, but the way it set up had me iffy on doing it, but its the only way the return could be set up.
Old Oct 24, 2010 | 12:23 PM
slvr 04 rl's Avatar
no ideas?
Old Oct 28, 2010 | 09:56 PM
slvr 04 rl's Avatar
the piping is 2.5 hotside and full 3 inch cold side piping. the welds on the blow off flange dont look too good. and thats because i got a CAST aluminum and its not pure.oh well. you cant see it lol
this just shows how tight everything is in the back. i had to cut a chunk out of the bracket to get the down pipe to fit.
and this is something i rigged up to keep the crank case pressure down. i dont think the oil is draining fast enough and blowing smoke through the tail pipe
Old Oct 29, 2010 | 02:23 AM
laser_racer's Avatar
You know you can hook that to your intake manifold as long as your put a catch can on it and also put a check valve inline to the manifold. So once you come in to boost it will shut and as soon as you let off it will pull full vac on the case. Looks good man hopefully this weekend or next week I will have free time so we can get your car all tuned up.
Old Oct 29, 2010 | 06:19 AM
joshcsepegi's Avatar
you still smoking oil? did you get that fixed?
Old Oct 29, 2010 | 08:48 AM
slvr 04 rl's Avatar
it does go to the intake manifold and there is i a PCV valve in the oil cap.
yes its still smoking oil.
Old Oct 29, 2010 | 09:27 AM
Lol I totally forgot that is what you did.
Old Oct 29, 2010 | 09:31 AM
rico's Avatar
wow very clean
Old Oct 29, 2010 | 09:43 AM
scotch89's Avatar
wow looks great man! hopefully you can figure the oil problem!
Old Oct 29, 2010 | 06:26 PM
slvr 04 rl's Avatar
lol yeah kendall
rico, i wanted to race your turbo lsj, guess ill try the teggy...
im going to try one last thing this weekend/monday. if that doesnt work i will send it back to the rebuilder to see if it was error on his part.
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
