Smaller pulley = less bottom end?
i felt a little dead spot around 3500-4000 rpm with the 3.06 stage 2 pulley .... that was fixed once i installed the 2.99 stage 3 pulley. no more dead spots now
No.. you're making more boost at all times, so it will create more power across the board (if you ignore heat issues).
The pulley only affects the speed of the supercharger, not the gear ratio of the drive wheels (as is the case with your sprocket example)
You should get a power increase through the entire band. You may lose a little bit up top due to heat and parasitic loss on smaller pullies. If the car isn't tuned well for a smaller pulley you could notice a bit of lag in the lower rpms. Also, on the GM stage 1 and 2 tunes you sometimes notice "lag" in the lower RPMs due to the tune itself slowly ramping into PE.
patooyee
Oct 1, 2015 01:07 PM
