Snow Performance Kit installation question
Old Aug 10, 2007 | 02:43 PM
burntorange's Avatar
Talking Snow Performance Kit installation question
Hey guys, I have yet another question that I hope/know you can answer. How far away from the throttle body do I drill and tap the hole for the spray nozzle? I will be running the smallest shot for now until I get tuned, but want to kick some ASS at the track this upcoming Wed. Thanks.
Old Aug 10, 2007 | 06:06 PM
splitimage's Avatar
the distance isnt a huge issue, i would install in on an upswing in the intake so if the intake isnt sucking properly it wont pool and clog, if u have an aftermarket intake, drill into the rubber section.
g/l trying to run it untuned, thats just stupid.
Old Aug 10, 2007 | 06:07 PM
Area47's Avatar
Rent me! per hour
mine is about 2.5-3 inches away from the tb itself
Old Aug 10, 2007 | 06:11 PM
yellowcobaltss05's Avatar
get the throttle body spacer from www.cobalt-addiction.com
Old Aug 11, 2007 | 12:31 AM
I would like to get the tb spacer, but my intake is 3" in diameter and was already a bitch to install and there just isn't enough space. Thanks for the info. Oh, and about not being tuned, yeah, I know that I do need to and HP tuners is on the way, just have a drag day on Wed and need to keep it from heat soaking on me. The smallest shot will not hurt anything, the ecu can adapt to that small of a change, plus, it is better to have it than without because it is going to be hot outside and don't want it to knock.
Old Aug 11, 2007 | 12:55 AM
Matty's Avatar
Same here.
Old Aug 11, 2007 | 10:30 PM
and did you all drill the whole directly into your aluminum air intake pipe? it seems too thin to tap. How do you fix the nozzle from moving/falling out?
Sean Cummings
Jan 8, 2020 10:17 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
lendsley
Sep 22, 2015 10:48 PM
