so my new stock colbalt ss is hitting 15-20psi? i need help!!!
please help me find out what is going on... my car was fine untill last night when i was driving down the free way and i went to merg and i noticed that i was hitting 15psi so i let off and tryed it again and it hit 20psi what the heck is going on
the car is all stock no pullie no ecu mods not even a cold air intake or exhaust.
i checked the code and it popped up
po101
po68
i think and the check engine light comes on for a few then turns off. the car shuts down after 15 psi i need help! asap! thanks
I aready replaced the blower pressure sincer on the top of the eaton so i dont think that is it. the car lot did that for me. cause when i got the car if you jumped on it hard it would power down.
po101
po68
yes do that..i have ott stage 1 i was also hitting 15 psi on stock pully but it was also 9 degrees at the time... i installed ott stage1 and hit 20 psi...i then bought the v2 header for 189 and used the stcok downpipe and cut off the cat and put a hks dragger muffler on...i hit 17.8 psi know and cant keep traction in 1,2 and part of 3 gear
