so my new stock colbalt ss is hitting 15-20psi? i need help!!!
Old Feb 28, 2009 | 05:56 PM
toolegit86's Avatar
please help me find out what is going on... my car was fine untill last night when i was driving down the free way and i went to merg and i noticed that i was hitting 15psi so i let off and tryed it again and it hit 20psi what the heck is going on
the car is all stock no pullie no ecu mods not even a cold air intake or exhaust.
i checked the code and it popped up
po101
po68
i think and the check engine light comes on for a few then turns off. the car shuts down after 15 psi i need help! asap! thanks
I aready replaced the blower pressure sincer on the top of the eaton so i dont think that is it. the car lot did that for me. cause when i got the car if you jumped on it hard it would power down.
Old Feb 28, 2009 | 05:57 PM
Bl4des's Avatar
clogged cat
Old Feb 28, 2009 | 06:00 PM
Jesse_Chouinard's Avatar
Originally Posted by Bl4des
clogged cat
yep, time for a new cat!!
Old Feb 28, 2009 | 06:06 PM
toolegit86's Avatar
that would cause it to over boost???
Old Feb 28, 2009 | 06:10 PM
EatonTVS07's Avatar
less flow more pressure
Old Feb 28, 2009 | 06:11 PM
Black SS/SC 06's Avatar
yep, its causing restriction which is why you are seeing higher boost levels!
Old Feb 28, 2009 | 06:12 PM
EatonTVS07's Avatar
what black said the asian said
Old Feb 28, 2009 | 06:21 PM
toolegit86's Avatar
the car only has 47k on it. i think i might jsut do the ott stage 2 and intercooler and jsut remove the cat.
Old Feb 28, 2009 | 06:59 PM
wtpcobaltss's Avatar
yes do that..i have ott stage 1 i was also hitting 15 psi on stock pully but it was also 9 degrees at the time... i installed ott stage1 and hit 20 psi...i then bought the v2 header for 189 and used the stcok downpipe and cut off the cat and put a hks dragger muffler on...i hit 17.8 psi know and cant keep traction in 1,2 and part of 3 gear
Old Feb 28, 2009 | 08:49 PM
my cat was replaced twice within 70K km!
Old Feb 28, 2009 | 09:48 PM
StreetDreamz's Avatar
I've seen cats explode on stock cars under 10,000 miles even.
Old Feb 28, 2009 | 09:49 PM
R&C_rallySS's Avatar
I love my old style ZZP 3" with highflow.
Old Feb 28, 2009 | 10:28 PM
tdipowered's Avatar
yea what the smelly foreigner said
Old Feb 28, 2009 | 10:38 PM
Razor564's Avatar
Mine was burnt up in 12k miles
Old Mar 2, 2009 | 12:48 PM
toolegit86's Avatar
yea i cut it off a cleaned it out. and put on a mangaflow muffler and did the air box mod. i like it now it stays about 12psi and sounds like a pissed off chainsaw
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
