Some Intake Questions
Old Jun 6, 2006 | 12:39 PM
John's Avatar
ok ive seen the pics
ive seen the prices
but i dont see newhere the resaults
looking for some facts on how much hps these intakes give
also im prob going with the k&n intake just cause its real k&n filter.
does the k&n bolt right on to the SC or no any info on this be nice?
also all these intakes are cold air so what would happen if u driving in the rain and suck up some water?
there are things u can put in between the fliter and throtle body is this nessasary?
Old Jun 6, 2006 | 12:42 PM
Rusty's Avatar
it will not suck up air unless the filter is submerged in water. performance depends on other mods to your car. my car stock w/ just the injen cold air intake dyno'd at 231hp. simple bolt on...there is a write up in the how-to section. if you search the forum, you'll find about 10,000 threads about cold air intakes.
Old Jun 6, 2006 | 12:53 PM
John's Avatar
alright thanks answered a few question i had
still need some info on the k&n
Old Jun 6, 2006 | 01:34 PM
NightriderCobaltSS's Avatar
I have the K&N CAI what else would u like to know my friend . Hope this helps.
I emailed K&N with a few questions myself.
Recently I bought a 69-4516TS CAI
1. How often should I check/clean my air filter?
2. If I choose to order a new filter for my 69-4516TS they are pre-oiled correct?
3. What is K&N's definition of Inclement weather it like a temp range, rain, snow, sleet?
i got a reply from K&N
1. The recommended cleaning time for the filter that you have is every 80,000-100,000 miles.
2. The filter that comes with the intake system is pre oiled and ready to install.
3. Inclement weather is defined as weather that would cause the filter to be submerged in water.
Old Jun 6, 2006 | 02:06 PM
chipsgt's Avatar
If your THAT worried about Hydrolocking the engine, buy a bypass valve from AEM and never have to worry about it again.
Otherwise, just use common sense and dont floor it through any lakes or ponds and it will be all good!
Old Jun 6, 2006 | 02:08 PM
Rusty's Avatar
80K to 100K? that's when you should replace the filter. you should clean it every oil change for best performance. i had a K&N filter in my camaro and seriously felt a huge difference every time i cleaned it. the cleaning kit is like $10 at pep boys and you can get at least 4 cleanings out of it. definately worth the time and effort.
Old Jun 6, 2006 | 02:24 PM
player_1's Avatar
I'm pretty sure that the bypass is useless on any forced induction system, as it is forced open when the charger starts to suck the air.
I know I read somewhere that it was for NA applications only
Old Jun 6, 2006 | 03:40 PM
John's Avatar
great info thanks guys
nightrider i guess this is the part # 69-4516TS CAI and cai means cold air intake right
also this k&n fits nicely right no rubbing?
Old Jun 7, 2006 | 08:31 AM
chipsgt's Avatar
I dont know if it has been a problem with the 06's, but I know a lot of folks with the 05's had a lot of problems with the K&N's throwing codes.
I dont think fittiment was an issue though.
There are hundreds if not more threads on CAI's. You can find more info on the codes that way.
Old Jun 7, 2006 | 08:48 AM
I do have an 2006 and i have the K&N 69-4516TS installed in my car. I have had it for two months with no CEL's. But we did it we did unhook the battery while we installed it . with mine the was no rubbing issuses.
Old Jun 7, 2006 | 11:43 AM
John's Avatar
thanks for the info guys once again
Old Jun 7, 2006 | 11:45 AM
cybcow's Avatar
I'd love to see the performance difference between the Air Box Mod and a CAI. Cause I honestly believe that a CAI for the SS/SC is a waste of money. Yay for Air Box Mod!
Old Jun 7, 2006 | 11:49 AM
John's Avatar
well i guess peeps like the look of a real CAI and dont want to mash up there stock boxs
Old Jun 7, 2006 | 11:54 AM
I know i may not need to but i keep all of my stock part just in case.
Old Jun 7, 2006 | 12:09 PM
John's Avatar
ya maybe for warrinty or something idk
Old Jun 7, 2006 | 12:41 PM
l Sh1ft l's Avatar
Air Box mod IMO is cheap.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Sep 25, 2015 06:06 PM
