Some problems
Old Oct 12, 2007 | 06:56 PM
Ljavy17's Avatar
Some problems
So I just changed my injectors back to stock and Now The car is acting like ****. I put the stock pulley back on. I have some Coolant in the bolts where the supercharger it held. If I drive it too hard the car goes into Limp mode and I am getting these codes.
p0068 map/maf Throttle position sensor SES (History) Immature
p0069 unknown Pending Unknown
P2229 Barometic Pressure sensor Circuit High voltage Pending History Immature.
WTF do I do!!!
I need some Freaking help on thissssssssssssssssssssssss
Old Oct 12, 2007 | 08:01 PM
silverSS's Avatar
stock tune also?
Old Oct 12, 2007 | 09:39 PM
Ljavy17's Avatar
Yup stock tune.
any thoughts???
Old Oct 12, 2007 | 11:08 PM
silverSS's Avatar
have you flashed the computer several times? could the stock tune be altered in any way? hmm idk man just trying to throw some things out there...
what all is aftermarket?
Old Oct 13, 2007 | 02:52 AM
splitimage's Avatar
could have something to do with your maf frequency, have u been watching it?
Old Oct 13, 2007 | 05:05 AM
LopsidedJester's Avatar
did you get a stage 2 upgrade or custom tune and then drop back the old injector size afterwards? Did you get your computer retuned after you changed injector sizes back?
Old Oct 13, 2007 | 03:23 PM
HunterKiller89's Avatar
he already answered both of these questions
i cant say what, but somethings wrong with your MAP sensor or maybe the wiring from it. Vheck it out, make sure its firmly in place and none of the wires are loose or anything.
Old Oct 13, 2007 | 03:30 PM
DebadgedBALT77's Avatar
check grounds on the wire for MAP, take it to the dealership, thats what we are here for.
Old Oct 13, 2007 | 04:20 PM
Stock tune doesn't quite answer what i was asking, sorry. Anyways, I didn't read anything on what tune and what injectors he was originally running unless i missed something. I did want to ask more on the lines of, how did you get it back to stock tune since you changed the injectors back? Because, I didn't know GM had a flash for that.
Old Oct 13, 2007 | 06:10 PM
Ljavy17's Avatar
Okay so it only does it once the car warms up. I put back the stock injectors, the stock pulley and the stock tune.
I did however take out the supercharger, so I think I might have moved something but why does it only do it once the car warms up.
I noticed is kind of overboosts while at idle. It just stayes at -10 insead of minus 20 so everytime I shift the RPMs dont drop. I took out the supercharger today and added some sealant and a new gasket but that did not do anything It still does it.
Where do I check the grounds for the wire for the MAP. where are those.
Old Oct 13, 2007 | 07:41 PM
well, first thing is to make sure all of your connectors are solidly connected and that the hoses to the S/C and intake are all securely fastened. It could be possible one of your sensors has gone bad if all of the wiring and hoses are fine. Have you recently removed the sensor on top of the supercharger or the MAP sensor? You can also check the seals around the MAP or SCIP sensor to make sure that they aren't leaking.
Old Oct 13, 2007 | 07:46 PM
Ljavy17's Avatar
ok, I have no Idea which one the SCIP and the MAP sensors are. lol. And I did take out the sensors on top of the supercharger and the throttle body.
Old Oct 13, 2007 | 07:52 PM
well, the SCIP (supercharger inlet pressure sensor) is the one on the top of the supercharger, atleast i'm pretty sure it is. Then there is the BARO (Barometric Pressure Sensor) sensor which is located near the throttle body and has wiring harness connecting to the wiring of the SCIP sensor. The MAP sensor is located near the left side of the fuel rail on the intake manifold (wedged between supercharger and engine). I wish i had some pictures, but if you haven't messed with the MAP sensor then it probably isn't the problem.
Your codes are pointing to a conflict between these 3 sensors, which means they should be thoroughly checked.
Old Oct 13, 2007 | 08:09 PM
Ljavy17's Avatar
Okay here is my question, How many sensors are connected to the supercharger. I think I only recall connecting one on top of the supercharger and one in the throrrle body.
Old Oct 14, 2007 | 12:38 PM
Ljavy17's Avatar
any help....
Old Oct 14, 2007 | 01:09 PM
well, i only know of one actually in the supercharger, and i believe thats the SCIP sensor.
Old Oct 14, 2007 | 01:19 PM
rnjmur's Avatar
I would also double check all your gaskets for leaks. If you have an air leak somewhere around the SC it could make the readings be off.
Old Oct 17, 2007 | 07:57 PM
uwishuhdmyecotec's Avatar
Check the vacuum lines, compare to another cobalt. maybe you hooked them up wrong. or you could swap the sensors with another good running cobalt to see if you have a bad sensor.
Old Nov 8, 2007 | 11:58 AM
Ljavy17's Avatar
Your post saved my life dude. Thanks a lot.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
