Sooo has anyone else had this problem?
Old Jul 12, 2008 | 11:24 AM
Tazmanian_Dvl's Avatar
Well last week I had my car in for service because the fuel gauge was reading erratically and they said the replaced the sending unit in the tank. I was like OK sound perfect. Well Saturday I was driving and in first gear I could take it all the way to the red line and in second I could only take it to about 5000 RPM's and it would cut out (almost like I hit the rev limiter but my limiter is programed to come on at 6500 RPM's) so I was like weird OK so I shift to third and I can only get to about 4300 RPM's and it cuts out again at this point I'm like WTF so shift into fourth and it cuts out at about 4000 RPM's and it kept repeating almost exactly like that the entire time I was out and I would step on the gas hard (if I increased the RPM's slowly and eased into the gas it didn't do it or do it as badly). Before I went home I stopped for gas (I had just under a 1/4 of a tank left) and when I turned the car back on the problem disappeared. So today I was out driving again and I was back around 1/4 of a tank of gas and kick me in the ass if the same **** didn't happen again! tried turning the car off let it sit and wen and had dinner came back and it did the same thing again. This time i went to the gas station and filled up and didn't turn the car off got back in the car and ****** A if the problem didn't disappear. I could red line every gear under hard acceleration. What do you think the problem could be? Do you think they could have hooked the fuel pump up wrong or put the wrong pickup in or what other thoughts do you have? I have to take it back to the dealer which pisses me off cause that leaves me with no car for the day! Any thoughts? I just want some ammo to go at them with when I take it in...
Old Jul 12, 2008 | 11:28 AM
ralliartist's Avatar
fuel guage reading wrong? How much gas do you put in it when you fill it up from a 1/4 tank?
Old Jul 12, 2008 | 11:30 AM
chevysssc's Avatar
that realy sucks
Old Jul 12, 2008 | 11:47 AM
when I filled up last night it was just below a 1/4 tank and I put 11 gallons in it...
Old Jul 12, 2008 | 11:50 AM
boostedss26's Avatar
sounds like the fuel pump cant keep up
Old Jul 12, 2008 | 11:51 AM
I knew I still had a few gallons to go because I reset my trip millage every time I fill up and I know I get about 320 miles to a full tank of gas before I absolutely have to fill up and the trip millage said 265 miles. It's almost like the dude that pit the pick up in doesn't have the pickup all the way at the bottom of the tank and when I hit the gas hard the gas shifts to the back of the tank and away from the pickup which makes the motor cut out...
I never had this problem until they put a new pickup in last week...
Last edited by Tazmanian_Dvl; Jul 12, 2008 at 11:51 AM. Reason: Automerged Doublepost
Old Jul 12, 2008 | 08:18 PM
Zach06CobaltSC's Avatar
Fill up your gas tank allllll the way up to the top and see if the problem happens. If it does, it has nothing to do with the gas tank and is another issue, in my opinion. I could be wrong however, it has happened before.
If the problem doesn't happen when the tank is full, and only happens when you are at say 1/4th of a tank or lower, then your baffle in the tank is not seated properly and is causing basically a surge at higher rpms because you are not getting the fuel you need. If you had a wideband, you would be able to see that you would be leaning out at the higher rpms.
I recommend taking the car to the dealership and having them redo whatever they did again because the issue was not fixed.
Old Jul 13, 2008 | 12:09 AM
yea it only happens under about 1/4 tank. This is the 2nd tank in a row that it's done that and it only started after the changed the sending unit and pick up.
Old Jul 13, 2008 | 12:26 AM
go back to the dealership with 1/4th of a tank and show them the issue then.
Old Jul 13, 2008 | 12:37 AM
Yea I am. I just hate taking it to the dealer because then I have to take a day off work because they refuse to give me a rental car. I just wanted to see if anyone had any thought what it might be so I could go in and rip em a new one.
Old Jul 13, 2008 | 12:55 AM
Dead Zen's Avatar
dude i think our cars have an 11 gallon tank.
Old Jul 13, 2008 | 01:02 AM
nope 13 but if you really try you can cram in about 14
http://www.edmunds.com/used/2006/che...tid=ik16231731
Last edited by Tazmanian_Dvl; Jul 13, 2008 at 01:02 AM. Reason: Automerged Doublepost
Old Jul 13, 2008 | 01:10 AM
Afterwind's Avatar
In 1 full day you used a tank of gas? Do you just bomb around for the sh*t of it. As far as I know gas is expensive everywhere?
Old Jul 13, 2008 | 02:14 AM
No m car wen into the shop on the 2nd with 1/2 a tank of gas. They replaced the sending unit and pickup. On the 6th I first noticed this and I filled up with gas and it disapeared. Drove it every day to work and where ever else I needed to go and the issue came back on Friday the 11th and I then filled up and it disappeared again...
Old Jul 13, 2008 | 02:38 AM
yea just take it back with 1/4th of a tank and show them the problem, tell them whats going on, and im sure they will be able to take care of it for ya.
Old Jul 13, 2008 | 02:40 AM
Effin frustrating because every time I take a day off work, because they won't give me a rental car, to deal with this kinda **** it costs me $500-$1000 on average because I work on commission...
Old Jul 13, 2008 | 02:58 AM
YellowBalt06's Avatar
thats happend to me a few times and a buddy at the track it happened to....it hasnt happend to me again since then knock on wood, but i was like wtf just happend filled like i hit a rev limiter
Old Jul 13, 2008 | 03:02 AM
yep I was like WTF I'm only at 4000 RPM's
Old Jul 13, 2008 | 03:19 AM
well if you have any days off that are coming up, just keep it above 1/2 tank and take her in when you have time.
Old Jul 13, 2008 | 03:25 AM
no days off until September. It blows! That's way I took it in the week of the 4th because I was off...
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
