spark plug gap?
Old May 21, 2009 | 08:19 PM
kyle1853's Avatar
spark plug gap?
ok i have the gm stage 2 kit ..and i have a 2.8" pulley i was wondering what should the gap be on the plugs in i get the ngk one step copper? and i was wondering what the gap be if i do the same setup but with 60lb injectors?
Old May 21, 2009 | 08:33 PM
Cefaln452's Avatar
.32 is what i run and in your case what i would run
that would be for the 60's
Old May 21, 2009 | 08:53 PM
kyle1853's Avatar
thanks, ok so now i just need to know without the 60's? anyone know?
Old May 21, 2009 | 09:07 PM
Cefaln452's Avatar
just a bit larger
Old May 21, 2009 | 09:40 PM
NexTnmE's Avatar
I run a .35 gap with the 2.9 and 42's...
Old May 21, 2009 | 11:09 PM
rukkee's Avatar
I ran a .033 when i had my SC , anything around .040 and it would hiccup in the higher rpm's ....spark blow out.
Old May 22, 2009 | 12:03 AM
kyle1853's Avatar
you ran .033, what pulley were you running?
Old May 22, 2009 | 12:08 AM
SSLOW06's Avatar
I just through the dam plugs in there i checked one and it was at about 33 aswell and these are the ngk7,s so they are super sensative to gap i didnt touch them and so far the car runs fine !
Old May 22, 2009 | 01:23 AM
rukkee's Avatar
A stage 3 pulley (2.99). I know it's a smaller gap than what alot of others are running but my car liked it the best. Idle was the smoothest out of all the different gaps i tried...... and i tried them all between .030 and .040
Old May 22, 2009 | 09:40 AM
ShortStack's Avatar
You do not need to change your spark plug gap if you change injectors.
The fuel flow rate doesnt change unless you change it in the tune.
.35" is just fine. Wouldnt go much higher than .38".
Old May 22, 2009 | 09:52 AM
Cefaln452's Avatar
you cant swap injectors unless you get tuned so that would mean yes, if you put a different size injector in you need to change you gap on this vehicle
Old May 22, 2009 | 09:56 AM
ShortStack's Avatar
No...
When you change your injectors, you just change the flow rate in the tune... you dont have to touch anything else..
Meaning that everything else (AFR and such) will stay the same..
you dont need to regap, because you arent making any new power.
Old May 22, 2009 | 12:45 PM
rukkee's Avatar
Originally Posted by ShortStack
No...
Yep , I think changing pulley sizes has more to do with gapping than injectors. Spark blow out suchs.
Old May 22, 2009 | 07:11 PM
kyle1853's Avatar
so what do you think i should try if i have a 2.8" ...032?
Old May 22, 2009 | 07:23 PM
arkkornkid's Avatar
start on the higher end of the spectrum and work your way down till you find one that works best for you. I think I ended up with .034
I wouldn't go highr than .038, so start maybe with .036
Old May 22, 2009 | 07:26 PM
1badBlueberrySC's Avatar
.33-.35 for your setup.... if you have issues then close it you usually don't want t go into the .32 and lower range unless you are running 2.7 or less
Old May 22, 2009 | 11:01 PM
Cefaln452's Avatar
You have to get a tune before swapping injectors no matter what... simple... if you think not just wait till your engine blows up
Old May 22, 2009 | 11:13 PM
Zach06CobaltSC's Avatar
You need a tune after upgrading/downgrading injectors however you do NOT need to change the gap on the plugs. For what the op is running he should be at roughly .035
Hopefully this helps clear some things up.
Old May 23, 2009 | 02:33 PM
kyle1853's Avatar
yeah i know i had the 60's in once but it blew up like a month later and i got a new engine and supercharger, i have hp tuners... but if any of you guys know any tips for the 60's tune that would be great thanks
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
