Spark plugs
Spark plugs
Right now I am running one step colder iridiums and the cars seems to be running fine. I am dropping to a 2.7 from a 2.8 pulley and getting tuned for my meth kit next weekend. Should I swap spark plugs to two step colder, copper or what?
I did some testing with some copper plugs and iridium plugs and found this:
I could run the Iridium plugs no problem with stage 2 (3.06 in) and stage 3 (2.99 in) pullies. Once I switched to my 2.9 pulley the Iridiums started causing rough idle and problems with acceleration. Once I put in the coppers the idle is smooth and the acceleration is like it should be again. I think it is a combination of the Iridiums not being able to move heat as fast plus the Iridiums having to have a smaller gap to prevent spark blowout that was causing my problems. The coppers just keep the temps down more plus they allow me to run the gap at .39 ~ .40 where as I was having to run the gap at about .35 ~ .36 with the Iridiums to make it run halfway decent.
You could change out the plugs if you want, but stay with the stock heat range.
Of course, you can always use another brand of plug if you want to but stay in the stock heat range. Changing your spark plugs doesn't net you any HP gains (unless the plugs are fouled of course), so there is no reason to change them unless you have to.
okay will do.....im quite a noob what is the heat range and does NGK make replace ment plaugs for the balt with the factory range?
bump!
bump!
You can always try the plugs. Hiccups are kind of hard to diagnose with a log. Could be number of things. Plugs are a cheap and easy thing to replace and gap.
My car "hiccuped" when I was GM stage 2 and then when I got one step colder iridiums gapped to .040 it ran better, but since I have dropped pulleys again and running meth...my last WOT pull in 2nd it "hiccuped"
my car would do that before i dropped to brk7e's , it wasn't often maybe only 3 times in the 2+ years ive had stage 2. After gapping the colder plugs to .35 i haven't had any issues since.
You could run 1 step colder plugs if you wanted but it isn't necessary, the stock plugs should be ok. If you are planning on dropping the pulley size below the GM stage 2 then you should definately drop one heat range on the plugs.
I am running a 2.7 ZZP pulley with meth 60lbs etc...I run 18.5psi boost and I run the Iridium NGKs BKR7EIX one step colder at .30 - .28 gap. shift at 7400rpms with no spark blow out. works awesome.
agentirons
Oct 16, 2015 02:11 AM
