Spark plugs
Old Nov 2, 2008 | 06:11 PM
johnladow07's Avatar
Spark plugs
Right now I am running one step colder iridiums and the cars seems to be running fine. I am dropping to a 2.7 from a 2.8 pulley and getting tuned for my meth kit next weekend. Should I swap spark plugs to two step colder, copper or what?
Old Nov 3, 2008 | 09:51 AM
flash13brandon's Avatar
You dont need to go 2 steps colder with those mods...the meth kit lowers the temp is the combustion chamber which allows you to run a hotter plug...I recommend 1 step colder coppers...
Old Nov 3, 2008 | 05:33 PM
ecotecon18s's Avatar
very good young grasshopper...
Old Nov 3, 2008 | 06:30 PM
2K5SS/SC?'s Avatar
John I know where we can get some BK7RE coppers locally if you want to do them while we're at it. That's what I run, and that is what I recommend on your setup.
Old Nov 3, 2008 | 10:43 PM
Littlegoose's Avatar
where locally?
Old Nov 4, 2008 | 11:14 AM
rnjmur's Avatar
I did some testing with some copper plugs and iridium plugs and found this:
I could run the Iridium plugs no problem with stage 2 (3.06 in) and stage 3 (2.99 in) pullies. Once I switched to my 2.9 pulley the Iridiums started causing rough idle and problems with acceleration. Once I put in the coppers the idle is smooth and the acceleration is like it should be again. I think it is a combination of the Iridiums not being able to move heat as fast plus the Iridiums having to have a smaller gap to prevent spark blowout that was causing my problems. The coppers just keep the temps down more plus they allow me to run the gap at .39 ~ .40 where as I was having to run the gap at about .35 ~ .36 with the Iridiums to make it run halfway decent.
Old Nov 4, 2008 | 11:24 AM
boltedbalt's Avatar
hey guys im on stock plugs now....*not to thread jack*....what are some good ones i was thinking NGK but what type and size and all that
Old Nov 4, 2008 | 12:43 PM
rnjmur's Avatar
What do you have done to the car?
Old Nov 4, 2008 | 12:49 PM
boltedbalt's Avatar
currently injen intake just starting mods.....next week i get cat back and BM shift + and thats all ill prolly do for awhile....atleast till spring
Old Nov 4, 2008 | 12:56 PM
brandondrecksage's Avatar
do you have a 2.0sc or a n/a 2.4?
Old Nov 4, 2008 | 01:05 PM
boltedbalt's Avatar
hahah i got a 2.2
ba bump
Old Nov 4, 2008 | 01:06 PM
JimzSS's Avatar
Stay with the factory heat range untill you are boosted.
Old Nov 4, 2008 | 01:08 PM
rnjmur's Avatar
You could change out the plugs if you want, but stay with the stock heat range.
Of course, you can always use another brand of plug if you want to but stay in the stock heat range. Changing your spark plugs doesn't net you any HP gains (unless the plugs are fouled of course), so there is no reason to change them unless you have to.
Old Nov 4, 2008 | 01:15 PM
boltedbalt's Avatar
okay will do.....im quite a noob what is the heat range and does NGK make replace ment plaugs for the balt with the factory range?
bump!
Old Nov 4, 2008 | 01:25 PM
rnjmur's Avatar
NGK Double Platinum PTR5A-13
NGK IX iridium LTR5IX-11
Stock gap is .053"
Old Nov 4, 2008 | 01:35 PM
boltedbalt's Avatar
which is better iv herd iridium is that true?
Old Nov 4, 2008 | 03:03 PM
rnjmur's Avatar
Iridium dissapates heat quicker than platinum and lasts longer than platinum, so you could say it is better. It also costs quite a bit more, which isn't better...
Old Nov 4, 2008 | 03:27 PM
suprchged's Avatar
mods in sig, my car wot 2nd it hiccuped a few times, and it would cut out but go right back to accelerating do i need to change plugs???
Old Nov 4, 2008 | 04:28 PM
rnjmur's Avatar
You can always try the plugs. Hiccups are kind of hard to diagnose with a log. Could be number of things. Plugs are a cheap and easy thing to replace and gap.
Old Nov 4, 2008 | 04:44 PM
My car "hiccuped" when I was GM stage 2 and then when I got one step colder iridiums gapped to .040 it ran better, but since I have dropped pulleys again and running meth...my last WOT pull in 2nd it "hiccuped"
Old Nov 4, 2008 | 10:24 PM
rukkee's Avatar
my car would do that before i dropped to brk7e's , it wasn't often maybe only 3 times in the 2+ years ive had stage 2. After gapping the colder plugs to .35 i haven't had any issues since.
Old Feb 14, 2009 | 02:14 PM
HeCTiC 6ft dp's Avatar
+2pts for resurrecting an old thread rather than creating a new.
I currently have GM Stage 2, Injen CAI, and Corsa exhaust. What plugs should I be running?
Old Feb 16, 2009 | 10:03 AM
rnjmur's Avatar
You could run 1 step colder plugs if you wanted but it isn't necessary, the stock plugs should be ok. If you are planning on dropping the pulley size below the GM stage 2 then you should definately drop one heat range on the plugs.
Old Feb 16, 2009 | 12:50 PM
HOT CARLS SS's Avatar
I am running a 2.7 ZZP pulley with meth 60lbs etc...I run 18.5psi boost and I run the Iridium NGKs BKR7EIX one step colder at .30 - .28 gap. shift at 7400rpms with no spark blow out. works awesome.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
