spark plugs
Old Sep 4, 2009 | 09:07 PM
DEZZIE41's Avatar
spark plugs
just wondering what some people are using for spark plugs for that little extra something somethign lol seeing as my car has 60 000KMS on it and prob still OEM stock day one plugs
also i have a cold air intake and a stock SS what type of plug would be the best and what to gap it out thanks
Old Sep 4, 2009 | 09:12 PM
kissrocker52's Avatar
i have been told the stock ones are good
Old Sep 4, 2009 | 09:15 PM
DEZZIE41's Avatar
i was told the same thign but i didnt know if there might be somehting else with a bit more bang persay lol being in Halifax i can only get so much
Old Sep 4, 2009 | 11:20 PM
Karlen89's Avatar
I run BKR7E's at .035. But, I'm not stock. :/
Old Sep 4, 2009 | 11:24 PM
OneCOLDBIZL272's Avatar
Im Running a NGK BKR7E @ .28gap but, i have a built motor with no stone unturned. had to gap that to stop spark blow out.
Old Sep 5, 2009 | 12:08 AM
Zach06CobaltSC's Avatar
Most people run ngk bkr7e's gapped around .035 - .040.
Old Sep 5, 2009 | 01:44 AM
fjordbosun's Avatar
If you are pretty much bone stock and your LSJ has the factory installed NGKPFR6T
Platinum plugs, you are set for life.They will out last your bottom end, lol. They are factory
gapped and do not need to be serviced unless they break for some reason. If you try to re-gap them you will most likely break the strap. They cost about $50.00 each to replace so if you ever do use another plug keep them, you can re-use them with no worries. If you do find that you are doing some mods and want something else for performance, go with a copper cored plug. With out regard to heat range, copper being a softer metal does not hold heat like platinum or even iridium type plugs and offer better performance, as they will run cooler, you need heat in the spark produced not but no heat retained in the plug making the spark. I use the NGK BKR7E, I use a lot of nitrous and change my plugs often, mostly due to electrode erosion.
Old Sep 5, 2009 | 12:55 PM
ShortStack's Avatar
50 bucks each? Nayyy... Its about 40 bucks to replace all 4...
I WOULD NOT suggest keeping the sparkplugs in for the entire life of the car.. that is just insane...
Old Sep 5, 2009 | 03:55 PM
fjordbosun's Avatar
Oops.... oh yeah about 50 bucks for a set, my bad. I'm not suggesting never changing
platinum plugs just illustrating their longevity. An old set platinum plugs lying around
might be all a person has in squeeze.
Old Sep 5, 2009 | 04:33 PM
2MCHBoost's Avatar
Use dollar copper ones. Been proven for a hundred years
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
