Spark Plugs! Help!
Old Aug 24, 2006 | 03:19 PM
BriantheLion26's Avatar
Spark Plugs! Help!
I just need some opinions one what spark plugs to get and what gap to set them at. I have a '06 SS/SC with the stage 2 and gmpp exhaust. I was looking at the NGK Spark Plugs BKR7e but I wasnt sure if anyone recommended any different ones or not. Thanks a lot!
Old Aug 24, 2006 | 03:25 PM
bump... any help?
Old Aug 24, 2006 | 03:31 PM
common!
Old Aug 24, 2006 | 03:39 PM
PlaysWitCars's Avatar
Former Cobalt Owner
I got some Autolite plugs from Intense that ive never used.....but i have the NGK's in mine
Old Aug 24, 2006 | 03:40 PM
DJMKAFKA's Avatar
Ngk Bkr7es I Have Mine Gapped(sp) At .40 No Issue Been In The Car Since Friday With Stage Ii And Gmpp Exhaust
Old Aug 24, 2006 | 03:43 PM
codyss's Avatar
If you aren't having any issues just leave the stock one in.
I tried the BKR7E and the Iridiums with major dead spots with different gaps from .35 to .40. When I took either plug out they were the perfect example of what a plug looks like when it is to cold.
I myself got rin of my minor issues by replacing my plugs with a fresh OEM NGK set.
Old Aug 24, 2006 | 03:45 PM
I was just wondering why we are supposed to run 1 stage colder plugs. I figured it would be better than the stock plugs. What is the stock plugs gapped at? 0.045?
Old Aug 25, 2006 | 04:26 PM
codyss's Avatar
Stock gap is .040, the information that states .045 is wrong
Old Aug 25, 2006 | 04:40 PM
zinner's Avatar
Moderator Alumni
Stock Gap for the LSJ is 0.9 mm (~0.035")
Old Aug 25, 2006 | 04:47 PM
SS33's Avatar
I'm runnin GM stg 2 w/ the 2.8
with NGK BRK7E's gapped at .038
Old Aug 25, 2006 | 04:48 PM
SS33's Avatar
My stockers were all at .040, i checked them as I swapped
Old Aug 26, 2006 | 01:21 AM
beamSS's Avatar
.40 works fine for me
Old Aug 26, 2006 | 02:49 AM
plyboy-illest's Avatar
from what iv heard the NGK BRK7E re the best too goo with
Old Aug 26, 2006 | 11:47 PM
OBSSSD's Avatar
You are correct but unfortunately few realize that
Old Aug 26, 2006 | 11:53 PM
Matty's Avatar
.035" is a good gap but the manual states .042" and when the stock plugs from the factory are checked they are .040" so it gets confusing.
Personally I have the ZEX plugs gapped the way they came and they work very well.
Old Aug 27, 2006 | 06:44 PM
2K5SS/SC?'s Avatar
My mods are in my sig, and the NGK's were the cause of my running badly. They were gapped at .040 and when i pulled them out they were hot white. Detonation for sure. I have the stock plugs back in for now, and they are gapped at .036. Much better thus far.
Old Aug 27, 2006 | 06:47 PM
Matty's Avatar
The iridiums were detonating?
Old Aug 27, 2006 | 06:49 PM
sethallen's Avatar
.40 is my gap with stage 2 +2.8" pulley
search man, there is at least 1987375983 threads on spark plug gapping
Old Aug 27, 2006 | 06:59 PM
2K5SS/SC?'s Avatar
I think it was detonation, which caused the car to pull timing. The car would pull, then sputter, and just plain ran like ****. I pulled the plugs and the electrodes were quite white which is abnormal.
Sethalen, I know about the plug posts. I've been here a while. I have done my homework, and obviously it doesn't work in my case. My car is always different it seems compared to others.
Old Aug 27, 2006 | 07:02 PM
Matty's Avatar
When I pulled the iridiums because of the detonation, they were really white. Up here they cost me $75 for the set....down the toilet.
Old Aug 27, 2006 | 10:21 PM
OBSSSD's Avatar
Now there is 1987375984 threads about it
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
