Spark plugs for SS/SC...
Old Feb 9, 2006 | 08:07 PM
Xenozx's Avatar
Regular platinum spark plugs...
Can these be used in our cars considering they are F/I?
I checked with the dude at autozone, and he doesnt see a problem with them. Figured I would double check to make sure. I bought a set of Autolite double platinum spark plugs.
Old Feb 9, 2006 | 08:56 PM
Xenozx's Avatar
anyone...
Old Feb 9, 2006 | 09:20 PM
SS_SC_Cobalt's Avatar
our cars come with platinum plugs, NGK PFR6T-10G platinum plugs
If you want to upgrade go to a copper or iridium, Personally I just installed NGK Iridium's today
Advance Auto 6.xx ea
Old Feb 9, 2006 | 09:29 PM
Xenozx's Avatar
Ive read a few places that Platinum plugs are not recommended for supercharged applications. We have them stock, is this why all the plugs ive seen afer like 10,000 miles all seem to be totally messed up and composited?
Old Feb 9, 2006 | 09:36 PM
I know turbo's dont like the platinums and iridiums, but we run much higher boost and a lot more heat, if your worried get a excellent copper plug if your worried, I plan to data log the car over the next few days to see how the iridiums work out....
If you are running higher boost then def stay away from platinums and iri's
I run 22-24lbs in my stage 3r srt and my plugs are champion coppers gapped .035
Old Feb 10, 2006 | 12:23 AM
Xenozx's Avatar
thanks for the info. I went ahead and swapped out my spark plugs a few moments ago. My dad looked at them and said they where really fouled for only having 5500 miles on my car.... My bro has a Ion redline with all the same mods and twice as many miles and his still looked better then mine. I included a shot of his below since we swapped em today too.
heres mine next to my bro's.. Mine are on the right his are on the left.
heres what the engine looks like with the top off.
Old Feb 10, 2006 | 12:25 AM
Xenozx's Avatar
Also thought I would note that since changing the spark plugs the wierd accell problem I was having seems to have gone away. I am going to let my car sit overnight and try it again in the morning, but everything was silky smooth once I changed SP's...
Old Feb 10, 2006 | 01:05 AM
CobaltCoupeCrazy's Avatar
Exclamation Silverstone Plugs from Nology
OK, why is it nobody seems to know anything about Silverstone plugs from Nology?? Also they have a complete ignition system for the Ecotecs. Check out these links:
http://nology.com/silver.html
http://nology.com/hot.html
http://www.nology.com/images/ecotecinstallation.gif
That inspire anyone a bit??
Scott
Old Feb 10, 2006 | 01:24 AM
cvenom2122's Avatar
Thumbs up
wires wont work on 2.0 but awesome none to least!
Old Feb 10, 2006 | 08:19 AM
Scott
probably cause they are not worth the $$$$ on a cobalt...we have a coil on plug setup that wont work with these.
Old Feb 10, 2006 | 08:57 AM
Mercury's Avatar
Just for future reference, how much tq do our spark plugs need to be torqued to?
Old Feb 10, 2006 | 10:48 AM
plyboy-illest's Avatar
i was just going to ask the same question
Old Feb 10, 2006 | 12:24 PM
Exclamation
My bad, I'm sorry you 2.0 guys can't use this system; but for the 2.2's it's a nice setup. Regardless, anyone can use the Silverstone plugs!!
Scott
Old Feb 10, 2006 | 01:10 PM
depends on the plug, ngk recommended 1/4 full turn past gasket contact point ....
Old Feb 10, 2006 | 02:26 PM
RonSS's Avatar
Xenozx,
Those look terrible!
Is your car stock?
How did it idle? Could you feel the engine shake?
I ask because mine does after it warms up, and it didn't when new. I have just shy of 5k miles on it now.
Do you drive a lot in stop and go traffic?
In reality, the plugs in any modern FI car should run very clean, almost to the point that they should look like new after 5k miles. No matter what kind of driving you do.
Keep us posted on how the car runs with the new plugs.
I will check mine this weekend, and if they look like that, then I'll know something is wrong with the injection, and it will go in for service.
Ron
Old Feb 10, 2006 | 03:52 PM
Jmc007's Avatar
RonSS the Cobalt SS/SC is really running rich from the factory.
Old Feb 10, 2006 | 04:10 PM
1stbluSS's Avatar
I thought our cars came with iridium plugs ? I purchased the NGK BKR7E PLUGS and I plan to put them in this weekend. JMC i see you have these plugs what was the TQ spec at install ? I see the little diagram on my box but I want to get some other installed opinions.
Old Feb 10, 2006 | 04:39 PM
cvenom2122's Avatar
Thumbs up
xenozx has intake, cat back 2006 ss/sc he has 5000 miles on his car I had 11000 on my 2004 saturn ion redline s/c w/ intake RAM air, jason smith header, and 3" cat back and my tips of my plugs wer perfect still
xenozx plugs '
venom'z plugs
I dont know why the hell they are so bad we will check them again in another 5k
we turned them until the were just tight then a 1/2 turn
Old Feb 10, 2006 | 04:46 PM
Jmc007's Avatar
Spark plug torque is 20 N-m (15 lb-ft).
Old Feb 11, 2006 | 08:36 PM
truray4's Avatar
A little trick for spark plug install. Use your middle finger and pointing finger to pull on the bottom of the ratchet. You won't be able to over torque this way.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
