SPDDMN's Winter build/Projects
Old Feb 25, 2014 | 10:29 PM
  #351
armcclure's Avatar
Originally Posted by mrbelvedere
there is nothing special done
It's not about it being special, it's about it being done RIGHT
Old Feb 25, 2014 | 10:39 PM
  #352
SylverSS/SC's Avatar
But Mr.B is special! Lol
Old Feb 25, 2014 | 11:00 PM
  #353
SPDDMN36's Avatar
Considering where most builds stop, id call it special.
Old Feb 26, 2014 | 09:03 AM
  #354
mrbelvedere's Avatar
its all of the shelf stuff
my sleeves
diamond pistons
total seal ap rings
bates springs
adj cam gears
custom ground cams
stock crank with extended key
gm bearings
bs delete
josh ported the head
that's all folks you don't have to spend 10 million to have a decent power plant
Old Feb 27, 2014 | 11:47 AM
  #355
SPDDMN36's Avatar
FIC 1200's and intake manifold acquired.
ZZP Short ram, 2.2 alternator, tensioner, and ac delete belt all on their way.
Visual mock up happened this morning for charge pipe and other bits but we got too cold...its -8*F and the high will be around 0*F stupid winter.
Old Feb 27, 2014 | 12:05 PM
  #356
armcclure's Avatar
Shoulda got a kappa lnf alt. Plug and play.
Old Feb 27, 2014 | 12:09 PM
  #357
InfraRedline's Avatar
I like the direction this is going!
Run it around 450whp or so and let it ride while you build the other motor (if thats the plan). If the motor is healthy and it is tuned right it will take it all day long on the stock block.
Old Feb 27, 2014 | 12:25 PM
  #358
SPDDMN36's Avatar
That is the plan indeed!
If I find one at a reasonable price ill pick one up Alan, I didn't even think about the kappa alt actually.
Old Mar 7, 2014 | 12:50 PM
  #359
SPDDMN36's Avatar
To answer your question Nick, yes.
I picked up a zzp short ram from a member here, I'll either be adding a maf plate to it or a maf housing. Then adding a BOV fitting to it and the charge pipe. Im trying to see what would be most efficient or if the housing routing will make much of a difference.
Old Mar 7, 2014 | 01:10 PM
  #360
574's Avatar
574
LE5 or LSJ tb?
where you getting your charge pipe from
treadstone has weld in maf's for about $30
Got my weld on bov flange off ebay for about $7
Old Mar 7, 2014 | 01:21 PM
  #361
SPDDMN36's Avatar
Originally Posted by 574
LE5 or LSJ tb?
LE5 tb
Friend is making it. He made all his own charge pipes and intake pipe for his evo and they look really good and the best part is he's doing it fo fwee!
I'll look there and I'm using zzp's bpv/bov. Uses radiator hose(i think) to connect it altogether. If I dont like it I'll search for an HKS like Alan is using.
Old Mar 7, 2014 | 02:09 PM
  #362
574's Avatar
574
No issue then because if your ordering a new bov it should come with a weld on flange
Old Mar 7, 2014 | 08:30 PM
  #363
SPDDMN36's Avatar
It doesnt bolt on and it didnt come with an instructions or which springs are what. Guess I'll be calling zzp monday.
Old Mar 7, 2014 | 09:00 PM
  #364
BlackielawlessSS's Avatar
Instructions would help.
Old Mar 8, 2014 | 12:30 PM
  #365
armcclure's Avatar
When running recirculating the spring isn't as critical. How many did It come with?
Old Mar 8, 2014 | 12:39 PM
  #366
SPDDMN36's Avatar
Came with 3 springs
Old Mar 8, 2014 | 02:37 PM
  #367
armcclure's Avatar
Hmm. I would just call.
Old Mar 8, 2014 | 02:58 PM
  #368
Shouldn't have to call about a product. Everything should be included that will give you the information to run it safely and properly on your car.
Old Mar 15, 2014 | 12:03 PM
  #369
SPDDMN36's Avatar
Overall I'd say it was cleaner than I thought it would be. I knew cyl 1&4 would be worse due to an issue i had a few years back. Pistons look to be in good shape though, can still see the original machining marks on them yet. Cylinders are pretty shiny and still show machining marks aswell.
Badmab header eth for sale...
Old Mar 15, 2014 | 12:09 PM
  #370
Not too bad! Youre an 05 right
Old Mar 15, 2014 | 12:13 PM
  #371
SPDDMN36's Avatar
yep, 93k miles
Old Mar 15, 2014 | 05:15 PM
  #372
armcclure's Avatar
You guys and your baby cars... I'm pushing (roughly) 400+ at 160k
Old Mar 15, 2014 | 05:55 PM
  #373
SPDDMN36's Avatar
on a stock bottom end?
Old Mar 15, 2014 | 07:38 PM
  #374
armcclure's Avatar
Yeah. Other than m8 arp timing chains guide bolts and auxiliary chain delete.
Old Mar 15, 2014 | 08:50 PM
  #375
Niceness right there
