Squints Black Beauty
Old Oct 10, 2012 | 12:18 AM
Rubbermaid_LSJ's Avatar
Ive seen charts that show even a 2.25" isn't performance robbing... Hell the GMPP exhaust is 2.25
I would first get some powell rotated mounts... best mod I spent money on was my stage 1 kit. While it wont add power, it makes the car behave much better on launches and makes the car much more "drivable"... Then a used 3" downpipe and a badmab is a good start for good money (I spent ~ $300 for that setup). (Welcome to Bad News Racing) has sales for the header at $155 sometimes. I prefer this currently to the LT since it is "Like stock" so replacing the downpipe wont be an issue if it comes to that. The longtube is a good piece, but at the time, I had a leaking DP and didn't have the $600 to shell out for the LT, I don't regret my decision its a decent quality piece.
Then I would work on finding someone who can tune for you and get injectors/smaller pulley + Tune
IMO the "cooling mods" (option B, H/E, etc) aren't worth it until you are past the point of reason (TVS, full exhaust, Meth/alky, etc) especially on a drag car that will be seeing short bursts of WOT.
Old Oct 10, 2012 | 12:27 AM
Haven07's Avatar
Cooling mods ALWAYS help...
Old Oct 10, 2012 | 12:40 AM
Squints's Avatar
yeah i looked into the h/e, the spacer kit from zzp, and option b from powell
Old Oct 10, 2012 | 12:42 AM
DiabeticKripple's Avatar
first thing you need to do is go dyno your car. then you can see the progress you make as you mod.
Squints's Avatar
tried looking up prices on the mounts couldnt find them. as far as the bad-mab vs the LT just thinking of going with the mid instead get the best of both. 2.5 DP. do you think upgrading to the 3" cat back exhaust would still be good or should i go with the 2.5 instead?
Old Oct 10, 2012 | 12:49 AM
Squints's Avatar
Before I will. That way I can post pics and track my progress
Old Oct 10, 2012 | 12:57 AM
Squints's Avatar
updated performance mod list
Old Oct 10, 2012 | 04:35 PM
Squints's Avatar
So what's the opinion on getting a larger TB
Old Oct 10, 2012 | 04:38 PM
carstedt's Avatar
Ls4 is touchy ported stocker would be better to start
Old Oct 10, 2012 | 06:02 PM
Squints's Avatar
Saw zzp had one that was a little bigger but required you to port out parts
Old Oct 10, 2012 | 06:05 PM
  #36
carstedt's Avatar
Thats the ls4
Old Oct 10, 2012 | 06:11 PM
  #37
CobaltItaliano's Avatar
Agree with the majority here that your better off getting 2.5" dp/catback instead of 3". its a quarter inch bigger than stock and still provides enough restriction. The ZZP 2.5" catback is outstanding along with the 2.5" highflow catted dp they have. As for header, I would go with badmab.
And if you plan on getting in the 275-300hp range your gunna need rotated mounts and possibly motor mount as well. The option B is a good idea, as well as the s3 heat exchanger from zzp.
Good to see your buying from reputable vendors and not cheaping out
Old Oct 10, 2012 | 06:13 PM
  #38
Squints's Avatar
cheap parts =expensive repairs
Old Oct 10, 2012 | 06:15 PM
  #39
Squints's Avatar
how much hp can my stock valve springs take reliably before i need to upgrade them.
Old Oct 10, 2012 | 06:19 PM
  #40
carstedt's Avatar
Ho or wut u can safely rev to
Old Oct 10, 2012 | 06:27 PM
  #41
carstedt's Avatar
Hp*
Also stock engine mount will be just fine just get rotated trans mounts
Old Oct 10, 2012 | 06:32 PM
  #42
Squints's Avatar
Both
Old Oct 10, 2012 | 06:37 PM
  #43
carstedt's Avatar
Sum rev 7400 with no issues id say 7-7200 max to be on safe side hp i couldnt tell u to be honest
Old Oct 10, 2012 | 06:44 PM
  #44
Squints's Avatar
So would be better to just port my stock one?
Old Oct 10, 2012 | 06:48 PM
  #45
carstedt's Avatar
Yes to start it definately gives it more response and later on u can do the ls4 if u want more
Old Oct 10, 2012 | 07:35 PM
  #46
Squints's Avatar
So here's a good one for you guys trifecta tune or Zzp's hptuner tune?
Old Oct 10, 2012 | 07:37 PM
  #47
carstedt's Avatar
Hptuners
Old Oct 10, 2012 | 08:14 PM
  #48
LS6Rally's Avatar
Vlave springs wont matter for HP. some people say 7-7.2K on stock parts. but if you go with bigger cams you NEED springs.
Old Oct 10, 2012 | 08:35 PM
  #49
hptuners even though I have trifecta lol. hptuners would better suit what you're going for
Old Oct 10, 2012 | 08:50 PM
  #50
Squints's Avatar
That's usually the route we go on our hot rods at the house don't change the springs until you get bigger cam don't get bigger cam until you get better pistons etc.
