ss/sc help problem!!!!!!
when i try to get on (50% to100% throttle)my car in second gear at high rpm(4200-6000)rpms it starts to spunder and surge. i called my buddy who tunes my car and we found out that im leaning out up top.so we tried richening up the top end didn't work still does it so we added even more fuel and it didn't work. we think i have a
1.clogged injector
2. clogged fuel filter
3.blow-by-god (i hope not)
im going to be doing a compression test sometime this week. are there any thoughts
*** before we hooked hptuner i checked my plugs think it was an electrical problem but they were fine
1.clogged injector
How'd you figure out you were leaning out? Plugs, coil packs and maf will all cause studdering up top and under boost. Of course so will the things you mentioned. Sounds like you're on the right track.
the plus are fine they are gaped to 32 they are the ngk two step colder
how could i check the coils?
here are my mods if that helps
2.7 zzp pulley
60lbs injectors
k&n typhoon cia
hp tuner tune
hurst short throw shifter
aem wideband
aero interceptor
ais alky injection- unplugged for now
mildly ported blower
drilled and sloted rotors
cobalt -addiction 3inch downpipe w/o cat
whisper resonator
magnaflow muffler 3inch exhaust
Last edited by heyitsmikey1987; Jun 14, 2008 at 07:35 AM. Reason: Automerged Doublepost
First give them a visual inspection to make sure none are bloated, and there are no cracks in the boot at the bottom. When that checks out pull a coil pack, keep it plugged in, throw a plug in it, ground the tip and have a friend turn the car over. You should be able to see it. SS/SC's aren't known for finicky coil packs but it's a possibility, with your car being an 05 I'd check it out. But coil packs won't cause a lean condition. I'd keep trouble shooting the fuel system first in your situation though.
Was your tune adjusted for the meth injection being removed?
i had that problem with my car aswell....i talkd to the guy who tuned my car an he said thats how the 60# react to our cars....but now theres a whole write up somewhere on the site from someone who got around the 60# studder problem from the injectors...if i find the link ill post it for you
not 100% sure if you need new ones the 60s are fine if you can deal with the studder...but if not then try an find bigger injectors...i have no clue who makes them bout i think...not 100%sure but i think there like 70 or 80# injectors but ask around about that tho
why would i need bigger injector i havent maxed out the 60
i know but thats how the 60s react to our cars... a few ppl already had this problem an they just kinda deal with it but someone went to a bigger injector an was fine....im just trying to give you advice on whats happening you know an as i stated about the bigger injectors i wasnt 100% about it
If your injectors are failing you'll notice a sharp lean bump on the narrowband on your scan log during wide open throttle if one is clogged or is shot, or a really dark spark plug if its stuck open.
If a coil is bad, you'll get a misfire usually as soon as you crack the throttle that you'll feel even when not wide open.
I think you might need a new tuner that knows how to tune a correct injector offset table or workable PE enabling qualifiers.
there are no sharp lean bumps on the log
edit nvm he has a wideband just read his mods again
I think SJSchafer has a thread about tuning injector offsets.
anyone know where i can buy 72 lb injectors
bump anyone got any ideas
Last edited by heyitsmikey1987; Jun 15, 2008 at 10:18 AM. Reason: Automerged Doublepost
checked it thats fine. i hooked my methanol back up and the car doesnt do it till closer to redline
